Question about Hotpoint Dryers
Tumble drier works but wont heat
Tumble dryer does not heat but otherwise works,rotates etc
  • shenderso614 Dec 29, 2008
    hotpoint condenser tdc60s
    Scholar:
  • 86 Answers
Hi can you tell me what make model etc.... I then can tell you what is wrong!
Posted on Dec 28, 2008
  • Kris Seymour Dec 29, 2008
    Ok excellent, What you need to do is take the back off to expose the heater, Then you will see 2 T.O.C.'s located on top of the heater sheald whick need to be convex in shape! ( do not touch them tho as your finger prints will break them) If you see on that is concaved then you need to replace both as they come as a pair! Let me know how you get on!
Whirlpool AWZ 7686 Tumble Dryer heater works for only 10seconds
Might want to check for an obstruction in the outlet of the exhaust
Well if you had mention that in the first place I wouldn't be asking you. No wonder your trying to fix the problem by yourself because with that attitude you can't get a technician to come out for service.
Sep 12, 2015 | Whirlpool Dryers
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Zanussi tumble drier is not heating up to dry clothes , but is working OK otherwise
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Dryers
Bosch WTL 5100 Tumble Drier rotates but does not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Bosch Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Jun 05, 2009 | Kenmore Dryers
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Dryers Logo
221 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
