SOURCE: 98 Dodge Durango no electrical power
When the armed Vehicle Theft Security System (VTSS) senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed after the battery is reconnected.
The alarm can be disarmed by locking the vehicle and turning the drivers door lock to the lock (arm) position. Wait a few minutes then unlock (disarm) the drivers door and the vehicle should start.
If the VTSS has been disabled in the high-line Central Timer Module (CTM), the VTSS feature must be re-enabled using the Chrysler DRB scan tool. The clicking you heard was probably from the CTM located behind the glove box.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: 2006 dodge durango 5.7 limited. engine light
Sounds right & check manual for warranty guidelines for your emission system & components, sometimes they are a little longer than 40,000 I believe.
SOURCE: 2006 Dodge Durango stuck in neutral
front pump failure or valve body internal leakage. Trans pn needs to be lowerred to ck and at a shop. Sorry
SOURCE: Reset the Tire Pressure Warning light.
well it depends, if you have just reset the tire pressures, the light should go off by itself, if it doesn't then you have a bad tire pressure sensor. If you have replaced the sensor, it must be programmed into the WCM by the dealership.
