Question about Seth Thomas Pacconi Turntable
Thomas Pacconi turntable turns too slow
I also have a Thomas Pacconi turntable that turns at the wrong speed. Came also from QVC. No help anywhere. Anyone out there have a solution?
  • dsarm511 Jan 19, 2009
    I have the exact same problem. I installed a new belt and it still runs too slow which leads me to believe it is a motor problem. The speed switch does run faster on the 78 speed but there does not seem to be any difference between the 45 and 33 speed. Not sure where to go from here. I did try the belt in the groove on the spindle on the drive motor (where I believe it belongs) and the fatter part at the base of the spindle but there was very little difference and it was still too slow (on 33 speed)
    New Friend:
My older Thomas Pacconi turntable was also turning too slowly. Rather than replacing the belt or needle, I tried using an eye glass repair screwdriver to alter the trimmers inside the motor. But the changes didn't take. Then I tried trimming the power to the motor using the larger trimpot next to the motor with the motor itself set to the 78 rpm setting. But the adjustments to the trimmer didn't get the platter to spin slow enough - it wouldn't play an LP. To get the speed down further I replaced the 1K trimmer with a 10K trimmer I picked up for a buck at Radio Shack and successfully adjusted the turntable down to down to 33 1/3 rpm usage. All that was needed was a soldering iron and a 10K trimpot to get the job done.
Thomas Pacconi turntable turns too slow - thomas-pacconi-turntable-turns-slow-rzuwuh3q1ggfdk4eh24l3p3x-4-0.jpg
Posted on Apr 01, 2015
  • 2,478 Answers
I have same problem. I hooked motor, need wiring diagram
Posted on Nov 15, 2011
I took it apart and the belt was off where it needed to be
Posted on Dec 29, 2008
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
My museum thomas series record player runs slightly too slow. How can I fix this??
Try changing the needle which runs on the record this is to do with clarity , makes a big difference and you get many types of needles
Dec 29, 2013 | Seth Thomas Pacconi Turntable
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
WHEN I PLAY A 331/2 RPM LP IT SOUNDS A LITTLE
The needle itself will not induce drag on the record. Even worn needles play no role in the problem you describe. The belt, provided it has suffcient tension to turn the platter, is doing it's job. The most likely source of malfunction is the motor itself. Try sliding the speed switch back and forth while the turntable is turning. If you see no difference in the speed between the 33 1/3 rpm setting and the 45 rpm setting, you have most likely eliminated all sources of the malfunction other than the motor. They are very prone to failure. If a replacement can be found, the job of installing it is not particularly difficult but indeed should be left to someone skilled at soldering electronic parts.
Dec 22, 2009 | Seth Thomas Pacconi Turntable
We have a Thomas Pacconi record player and the band underneither the turntable has stretched out. The band is black, about 1/4" wide, and round. Can you help us.
TBirdMM, thanks for the advice. I was turning that dial this morning tweaking the rpms and it worked! Strangely enough I actually broke the white dial off, but when I spun a 33 on the 78 setting it played right on! Thanks!
Does anyone know why that dial only effects the 78rpm setting, and if there is a dial for the 33 rpm setting?
Jun 09, 2009 | Seth Thomas Pacconi Turntable
Speed problem on Thomas Pacconi Turntable
probably need the rollers rebuilt
check out needledoctor.com
Dec 02, 2008 | Technics SL-1200MK2 Turntable
Seth Thomas Pacconi Turntable Logo
1,984 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Vito Vacirca Jr.
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
