Question about Nokia N73 Cellular Phone
Phone memory i've problem with my memory phone... it's always full of memory when i turn it on.. i've try to restore my phone memory using keyword " *#7370# ",but it still with the same problem.. so,is there anybody can fixed my phone problem???...
  • 41 Answers
Format the memory
Posted on Dec 30, 2008
Unable to send message in my nokia N71.. how to fix this??
Please try by restoring your factory. Menu>Setting>Restore factory setting. or press this code *#7780# and if you want to format it than try this code *#7370#
else please check your message center number from your friend or family that they are using the same service(s) like vodafone, aircel, bsnl, airtel. from there check their message centre number whether it's the same number or not that's in your cell-phone. If it's not same than correct it and try.
Thanks for using FixYa
Sep 15, 2012 | Nokia N71 Cellular Phone
Tip
How to make your nokia phones work smooth and fast and keep it maintained.
The usage of the phone memoy in nokia phones is the main reason for slow functioning and hanging. So always keep 80% of the internal memory free or smooth functioning of the phone. For data one can use a memory card.
If the phone memory is mostly used or full transfer the files or delete it.
the only problem for freeing space in symbian phones is it needs to be formatted because it has many hidden files of the installed applications in the phone memory. So you can format the phone by dialling *# 7370 # or by pressing the Switch on + * + 3 + call button when the phone is off.
on Jan 13, 2010 | Cell Phones
Actually I want to format my phone memory of Nokia 3110c as whenever i try to enter confriguation setting for GPRS it gives me errot target memory is full, Inspite there is nothing there in memory?
Hello, enter *#7370* into the phone to restore it to factory defaults.
let me know how you get along with that and if you need further assistance.
Jan 30, 2011 | Nokia 3110 Cellular Phone
How to reformat
If you like to restore only settings using Restore factory defaults in the mobile.
If yu like to format your phone follow below steps
If you know the security code you can use *#7370#it will full format,
Full format means it will delete all data in the mobile.
If you have forgotten security code you can follow the below steps
Press green dial key, 3 and * at a same time when switching on the phone for hard reset in case of forgotten security code.This will erase all the contents in phone
Detailed explanation http://www.wikihow.com/Format-Nokia-N73
Oct 19, 2010 | Nokia N73 Cellular Phone
My phone is always in offline mode though i changed the profile settings many times. also, my phone always says "memory full. delete data first" though i tried doing *#7370#..it only restored the original...
memory full , remove ur mmc 1st then *#7370# format again, test the phone with out mmc, post result
offline mode mean no sim card detect, try other sim card post result
if cant u need flash the phone with new firmware
Jun 08, 2010 | Nokia N73 Cellular Phone
Always prompted that memory is full.
heres how
you can put *#7370* - hard reset
or you can restore using the following buttons * key, a number key 3, green/call key : hold all of them down at the same time and power on your device do not let go off the buttons until you see the nokia screen or handshake screen only then you can let go and the phone will restore the original state, you will lose all your data on the phone
Jan 17, 2010 | Nokia N73 Cellular Phone
I want to formate my phone memory. give me the formating code
A magic word : PLEASE.
In the setting menu scroll down to security then factory settings and choose restore. Or try *#7370#send.
May 12, 2009 | Nokia 6500 Slide Cellular Phone
Problem in profile
at firat take a backup from your phone on memory card then restore it to factory setting or enter *#7370*. your phone will format and you loos all information in your phone! restore the backup from memory card.
Apr 15, 2008 | Nokia N95 Cellular Phone
Phone memory protected
Under Menu>Contacts>Settings.... Under memory in use, change it to phone and SIM. It will probably ask for a security code which should be in your book, if you haven't changed it, its something like 0000 or 12345 or similar. then you should be able to copy all to the simcard.
Good Luck esm_taher@yahoo.com
Jan 14, 2008 | Nokia 7370 Cellular Phone
Nokia n95 Phone memory full
Hi there:
For months I've been searching on the Internet looking for a solution to my problem for my Nokia N95
It kept on saying that my phone memory was low and every time i deleted stuff (Including apps) the memory kept on eating away at its self with none of the memory that was there nowehere to be seen.
Save all your contacts and stuff you cherish on ur phone memory before u do this !!!!!!!!!!!!!!!!
I tried the factory reset ( *#7370# ) and the software reset ( *#7780# ) entered the code "12345" after each one and they both reset.... entered my country, date, time etc.... but it never sorted out my memory problems
Another reset is the 3 button reset... this worked on my phone and thank F**k it has :-)
what you do is switch off your n95 turn it back on but keep ur fingers pressed on the:
The star button ( * )
The number three button ( 3 )
And the Green button ( one you start to make phone call with )
did the same with the country date time and brill 140 Mb's free memory yee haaaaaaaaa
Oct 18, 2007 | Nokia N95 Cellular Phone
Nokia N73 Cellular Phone Logo
315 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
