Question about Toshiba RD-XS52 DVD Recorder
INCORRECT DISC - C104
For the first few months after I bought the TOSHIBA HI-FI VCR & DVD VIDEO RECORDER D-VR6KC, I had no problem recording and playing back DVD-R disks. Gradually, over time, I'm getting more and more error messages saying INCORRECT DISC - C104. This is happening no matter which brand of disk I use (Same brands I used before, when I had no problem.)
I feel that it's the machine, and not the disks. What might be the problem?
  • 10,594 Answers
You are right, Its machine giving problem.
As you said, its few months old so I think it is still under warranty, do not open it and call Toshiba for remedy.
Posted on Dec 28, 2008
    Sergeant:
    Champion:
  • 304 Answers
Try to clean the optical lens. you will need a cd lens cleaner for this job.
  • Toshiba Master
  • 13,433 Answers
You probably have a dirty lens, try a dvd lens cleaner.
Look for one locally heres one example
http://www.amazon.com/Maxell-DVD-LC-DVD-Lens-Cleaner/dp/B00000JPPI
  • 837 Answers
Have used a cleaning disc yet?
  • Jay Glendenning
    Jay Glendenning Dec 28, 2008
    Warranties are good for failed equipment but not due to neglect or misuse, etc.
    You are responsible to keep it clean.
    Get a cleaning disc
Toshiba D-VRW1 DVD recorder. I am getting Incorrect Disc C104 on almost every DVD I record when it's time to finalize the disc. This never used to happen until just a few days ago.
Hi...Try the usual DVD LENS CLEANER. DVD LASERS do fade with time so you have to replace that either in the shop or by a new player.
Mar 21, 2018 | Computers & Internet
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
DVD-RW will not record. Using Memorex DVD-RW and get the "Incorrect disc C104" message. Where can I get the correct disc and what are they? these used to work, but the new ones don't.
I have the same machine and I've used Memorex DVD-RW 2X/4.7gb/120min dvd's for a long time. The newer ones at Officemax are 4x, 8x, 16x and 52x they won't work. I think they have to be 2x only!!!
Nov 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Open Questions:
Toshiba RD-XS55-S-TU corruption of video after firmware update This recorder is around 2 years old and was functioning fine. Occasionally I'd have a problem with corrupt pixels when copying from DVD-RAM to the HDD (never from DVD-R for some reason). I complained several times to Toshiba and they claimed since I am in Japan it is due to the Hz issue (50 Hz versus 60 Hz). I do use a transformer to provide 120 volts. However pulling the plug for 3+ minutes usually solves the problem. I upgraded to the latest firmware hoping it would solve these issues. At the termination of the update, the last couple of steps of the instructions did not occur (similar to another poster complaining of this problem). I pressed the standby switch for 10+ seconds but I did not get a 'Wait' message nor did the tray close automatically. I had to pull the plug to gain access to the recorder. The recorder starts up fine, except I have a chronic problem with corrupt pixels now whenever I dub from DVD-RAM to HDD. I have tried pulling the plug for hours and as long as a day, but no help. I also have problems with the recorder locking up during scheduled recordings: I turn on the TV and the image is locked in mid recording and none of the buttons on the recorder works to turn it off so I have to pull the plug. Of course I lose the recording and all scheduled recordings after that. Sometimes the audio would just plain fail. Toshiba wants me to send the unit in for repair at a cost of $150 but freight by U.S. Postal Service from my FPO AP address to the U.S. will run $40! I told them why should I pay for repair when it was caused by their firmware update??? I notice they have subsequently pulled the firmware file from their site, no doubt due to my complaints. Any suggestions on how to fix the recorder and/or get Toshiba to repair it at no charge, which I feel is a fair demand? I have already tried to format the HDD several times (using the Toshiba instructions via the recorder) and tried the firmware update again 3X to no avail. I even tried to use the Canadian firmware update for this unit but the recorder won't recognize it.
Feb 27, 2017 | Toshiba RD-XS52 DVD Recorder
Toshiba RD-XS52 DVD Recorder Logo
548 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
