Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Freezer alarm light and temperature are flashing
  • 76 Answers
You have a cooling problem, check compressor, of evap fan if you have one
Posted on Jan 02, 2009
I have a Baxter ov310e oven a customer asked me to check on. Of course while there had no issues at all. She said when they were using it earlier in the day the temp diplay started flashing. It was near...
SAFETY ALARM (STANDARD FEATURE, NO PARAMETER SETUP REQUIRED)If the temperature at the probe is in range of 570 to 600°F for 10 seconds, the unit will do the following:1. Shut off all features.2. Sound an alarm.3. Flash the OVEN TEMP display (actual temperature is displayed).4. Display the letters 'SHdn' in the BAKE TIMER display.Disconnect the electrical power to the oven and follow lockout / tagout procedures.There may be multiple circuits. Be sure all circuits are disconnected.
Troubleshooting - Baxter OV310E Operation Manual [Page 29] https://www.manualslib.com/manual/1248539/Baxter-Ov310e.html?_e_pi_=7%2CPAGE_ID10%2C4341941345 -- shared by UC Mini
Jan 19, 2018 | Baxter Ovens
Samsung SRS615DP Refrigerator
The temperature indicated is wrong because the thermostat sensor is faulty.
The faulty sensor (thermistor) send wrong info to display, and as it is also a thermic switch it turns off the compressor before it reaches temperature.
Insert model number here and get replacement part. On the website you also find info on replacement.
Jul 10, 2008 | Ovens
My Kenmore Model 91195371790 oven Preheat light comes on as soon as you turn oven on and then flashes f2
Over-temp condition due to either oven temperature sensor or ERC (electronic range control).
Testing should be done by a qualified tech to prevent risks to user.
Jan 16, 2015 | Kenmore Ovens
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
Flashing Locked light. Cannot open the oven door
The oven is locked because the temperature inside the oven has not dropped below the locking temperature. Press Clear/Off button and allow the oven to cool. Oven door should open once it has been cooled below the locking temp.
Feb 17, 2011 | GE Profile JKP18 Electric Single Oven
The oven keeps blinking F2 what does that mean
F2 Heating mode high temperature This alarm is activated when the ERC senses a runaway heat condition or when the temperature exceeds "runaway limits". The ERC will beep until the cancel or another function is selected. If the alarm repeats the F2 code check the oven sensor and wiring after first checking for a stuck relay. If alarm goes away verify the oven will complete a clean cycle without any type of failure.
Nov 25, 2010 | Dacor Ovens
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
I have moved into a house about 11 years old. I started the self clean and now about two hours into it an alarm is going off signifying "F2 door locked". Can't turn off alarm :-( Don't know part...
F2 During CLEAN The Control is senses oven temperature above 915F-930F. If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC). If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches. Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 03, 2009 | GE Ovens
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
