Question about Maytag MGC5430 Gas Cooktop
MGC5430 NONE OF THE BURNERS SPARK
This is the fix to ALL burner ignitors dying at the same time. The spark module (parts select PS2003170 or Maytag Part No 12001596) has gone bad. Follow this link to see schematics and ordering information from www.partselect.com:
http://www.partselect.com/ModelFrames.aspx?ModelID=133177&ModelNum=MGC5430ADB&mfgModelNum=&ManufactureID=1&Selected=52668&Position=0&mfg=Maytag&Type=&Mark=0
I would suggest purchasing the bracket in case it mounts a little different than the original. Also, click on the part number for the module and when that link opens up, click on "There are 4 Do It Yourself...." to see experiences of other people who have done the repair.
If you want a cheaper price, check www.partstore.com with the Maytag part number.
5 Suggested Answers
SOURCE: Elect Ign not sparking, but get gas, other appliance working.
I don't know, I did nothing, it just started working again??????
Posted on Jan 29, 2009
  • 222 Answers
SOURCE: maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Posted on Jul 04, 2009
heatman101
  • 43501 Answers
SOURCE: I do not get spark,
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
kapishtech
  • 2272 Answers
SOURCE: None of the 4 burners
The burner may not light if the ignitor is damaged, soiled or wet. The spark is not coming because igniter is weak. the problem with your oven is a bad igniter.
Let me explain how it works:
The igniter is wired in series with the burner valve. When the thermostat calls for heat, line voltage is applied to the circuit. As the igniter begins to glow, the current increases. The current flow causes the valve to open when the igniter becomes bright red (almost white). Flat igniters operate from 3.2 to 3.6 amps. In your case the current is less then 3.2 amps and even it does glow it does not open the gas valve.
Replacing the igniter should solve the problem.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 02, 2011 | GE Cooktops
MODEL MGC543OBDS GAS STOVE THE ELECTRONIC STARTERS ALL FIRE WHEN TRYING TURN JUST ONE ON..
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 29, 2010 | Maytag MGC5430 Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Electronic ignition sparks continuosly (even when burners are off).
one of your electronic ignition switches is bad and burnt closed telling your spark module to spark
call applaince parts pro
1-877-477-7278
tell them u need part number
AP4101545 ignitor switch
18.00 dollars
they sit below the top under neaqth the selctors
you will have to go one by one
but the wires push in and pull out
Oct 04, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
Maytag stove top gas ignitor keeps clicking
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
My Sears cooktop electronic ignitors burners click periodically.
the spark module is grouning itself out. moisture will do this to it.
Jun 10, 2009 | Maytag 30" Built-In Gas Cooktop - White
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Feb 24, 2008 | GE 30 in.Profile JGP945 Gas Cooktop
Maytag MGC5430 Gas Cooktop Logo
310 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Marvin
Marvin
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
