Question about Proton MM2701VT 27" TV
POWER UNIT SECTION
WHEN ITS ON THE POWER SECTION FUSE DAMAGED
  • ravi chandran Apr 25, 2007
    I CHECKED THE TRANSFORMER ,DIODE AND CAPACITOR
    Problem Solver:
  • 11 Answers
It has a short ckt.please replace the STR and the H-out transistor for sure!
Posted on Nov 28, 2007
Sylvania SRCD 820 4 in 1 unit powers up, cd diplay blinks (as if searching), but no power to the cd drive unit, hence, sled will not move and disc will not spin. Is there a fuse for the cd mechanism?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 29, 2016 | Audio Players & Recorders
Samsung printer 110v plug to 220v
You would have damaged the power supply section but in many cases the front end contains a surge protector with a variator which will short and blow the fuse. So check fuse replace and check for short in the input circuit of the power supply, if the Switch mode is damaged then you need to replace the unit with a 220 volt type or if only the 110 type is available then use a step down transformer to down the mains to 110V with about 0.5Amps
Oct 03, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
My Bose radio stopped working, no sound no lights AWRCC1
Hello
Check its power cord first. If it is OK, check its power supply section inside. There will be a fuse at the power supply rectifer board. Check it. If it is found opened [damaged] never put an other fuse, without proper check to the power supply and main audio amplifier section. There must be some reason for the blow up of this fuse. Without rectifying the fault, replacing an other fuse, may make more components to get damaged, and the repair work may cost more. OK.
Feb 26, 2012 | Bose Wave radio/CD remote control -...
Emerson mod. ewc 1301 keep blowing fuse
Hello
There must be a direct short in its power regulator section. Normally a shorted switching output transistor at power regulator section will cause this fault. You have to check all the components in the power supply switching retulator section, including rectifier diodes, zener diodes, electrolytic capacitors, small signal switching transistors etc. In fact, you have to check the components in the entire power regulator system. Never put any more fuse into it as an experiment; this will make more components to get damaged. Check the sets' circuit well. OK.
Jul 27, 2011 | Emerson EWC1901 Combo
I am using philips g 370 trimmer , i got this from USA, when i have kept for charging ,light is not getting displyed on the adaptor. is there any other way that i should go
Make sure that the voltage of the unit is according to the device as if you have plugged in a 120volt unit into a 220 volt supply the adapter or the power supply would be damaged.
So please check this out , if not check the power supply section of the adaptor for failure of fuse or powerr components.
Jan 06, 2011 | Philips G370 Hair Trimmer
Fuse problem
Why it always blew, then you have a short circuit. It is not your fuse is the real problem because it is a guard to your unit. Once there was a short circuit it will blew to avoid further damaged to some parts.
It is commonly due to a shorted parts on the power supply section. You must isolate the shorted parts to back your unit to normal.
If you are not a technician then you must look for a qualified one to trace the shorted parts. This will fix your problem.
Thanks for using fixya.
Jan 06, 2011 | Mackie SWA1501 Subwoofer
Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Apr 02, 2010 | ButtKicker BKA1000-4A Amplifier
Behringer super x pro.the fuse keeps blowing on the ac inlet(t200 MA).a replacement unit works fine in the system.
When a fuse keeps blowing suspect an overload in either the power supply section or main amp part.
Look for burnt or damaged parts first.
The suspects in the power section are: transformer, diodes, rectifier, voltage stablizer, regulator.
In the Amp Section anything on the heat sink.
Jan 12, 2010 | Audio Players & Recorders
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
The reason the fuse blew again is that an overload has occured. It could be a faulty part in either the power supply section, or the amp section. Follow the curcuit from the fuse, be on the look out for damaged, burnt parts, suspect anything on a heat sink.
Nov 30, 2009 | Audio Players & Recorders
110 Volts plugged in 220
More than likely just the power supply would be damaged, it should blow before the rest of the unit gets damaged. Maybe even just the fuse inside where the power lead connects is blown.
Mar 08, 2008 | Harman Kardon AVR 135 Receiver
Proton MM2701VT 27" TV Logo
43 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
