Question about Adobe Photoshop CS for PC
Cannot achieve accurate adjustment of Photoshop's cloning tool.
After installing Elements 6 in a PC running Photoshop CS I found that the cursor (brush size circle) of the cloning tool was no longer accurate. The area cloned was much smaller than the area circumscribed by the "brush" size indication so that accuracy is impossible.
  • gillesp541 Jan 30, 2009
    Thanks for your sugestions but brush size selection was not the problem.
    The cause and solution of the problem popped into my mind a few days ago. I am learning to use a Wacom Intuos both for word processing and photo processing. I was using a Wacom pen (stylus?) that is designed to vary brush diameter with pressure. However it was unable to approximate the size of the cloning tool brush. Simply switching over to a mouse solved the problem. The stylus is great for selections but not for cloning.
    Novelist:
    Scholar:
  • 64 Answers
Gillesp, I tried to replicate what you were saying and I couldn't 'make' it happen. I was thinking along the lines that you had some airbrush setting on, but even that would not reduce the clone amount by much.
something you can try is to go to your brush size drop-down pallete (in the top right corner) and across to the options arrow and down there there is "Reset Brushes" - this will remove all your custom brushes and reset it to installed defaults.
Another thing, I don't know how much you know about this, so forgive me if I'm telling what you know: When you have the rubber stamp tool or paint brush or pencil tool or eraser selected, there is a drop down option of brush sizes and types in the top left corner of the window under the menus - here you can select the size of brush, but also change the characteristics of the brush, whether the edges are soft or hard and its size and intensity. If you weren't aware of this, try adjusting these settings.
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Jan 30, 2009
  • Dot Ball
    Dot Ball Feb 01, 2009
    If you're getting use to a new Wacom Intuos, keep at it. It is well worth it - especially for anything brush related. I use one myself and if set up right there are a ton of customisable functions that will make your work easier.
    Now you mention the tablet, it's obvious - your brush size is governed by the pressure you put on the pen. If you go to Start>Programs>Wacom there is a utility there where you can customise your tablet and pen and adjust the sensitivity to when the touch of the pen is recognised, how hard you have to push to get maximum pressure, etc - I suggest if you are not using your tablet for cloning, go here and set the sensitivity low, so you get maximum brush effect when just touched.
    Personally, I like the flexibility of adjusting my brush size without having to change brushes - just the pressure on my pen.
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Jul 02, 2011 | Adobe Photoshop 7.0 for PC
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
When attempting to start Adobe Photoshop Elements 2, I get this message " Could not complete your request because of missing or invalid personalization information." Using a PC running XP home service pack...
OK, loads of different fixes for this, have fun.
These errors are caused when a version of Photoshop CS is already on the computer, such as a beta copy, or if your registration information file does not get written properly or is damaged. If multiple copies of Photoshop are in the Applications folder, or if a beta or tryout version is installed in addition to the regular version, the system and Photoshop may confuse which files to use to verify personalization. This confusion can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder in alphabetical order. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
Do one or more of the following solutions:
Solution 1: Remove and then reinstall Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's splash screen upon opening Photoshop, you may have another version of Photoshop CS on the computer. Empty the trash, remove the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
To remove and then reinstall Photoshop:
2. Delete all Adobe Photoshop CS folder(s) in the Applications folder.
Solution 2: Remove and then reinstall Photoshop in another location.
If you uninstall and reinstall and still get personalization errors, or if you cannot locate an installed copy, uninstall any copies you find, empty the trash, and then remove Photoshop, and then reinstall Photoshop in another location that is alphabetically in front of any other installation.
To remove Photoshop and install it in a new location:
1. Move any personal files from the Adobe Photoshop CS folders on the hard disk to another location.
2. Delete all Adobe Photoshop CS folders in the Applications folder.
4. Create a subfolder in the Applications folder, that is named differently from the default Photoshop install folder (Adobe Photoshop CS), and is is alphabetically in front of the other version of Photoshop, such as \Applications\aaaa\Adobe Photoshop CS.
5. Reinstall Photoshop CS and select the new subfolder (created in Step 4) as the install folder when prompted for the installation location.
I know its a lot, but Adobe is a complicated program:) Source(s): http://kb.adobe.com
Aug 10, 2009 | Adobe Photoshop Elements 2.0
How can we change the color of the clone stamp tool pointer?
You can't. You can change the size by going to Edit > Preferences > Cursors, but you can't change the colour.
Instead you will see colour shifts depending on what background colour is underneath the cursor. It's generally darker over light colours.
May 02, 2009 | Adobe Photoshop CS for PC
Clone tool for Photoshop elements 6 not working
I just replied to this question of yours on another post.
I also, reading it again here, notice you would "hate reload it..." - pls note one of my options, to delete the preferences, is as reloading as what you are doing is deleting all that you have customised in the program. Read below, again....
I have not experienced this, but there's talk about some plug-ins effecting the clone tool's function.
A couple of suggestions to try:
- Remove you third party plug-ins one by one until you find the one that affects how the tool works. Bare in mind that some removals may require a restart to be effective.
- Delete your Photoshops preferences, hold Ctrl+Alt+Shift when launching Photoshop until a pop-up window asks you are you sure you want to delete the preferences. NOTE that this will delete all your p'shop settings and customisations, it'll be like you've just installed it again. Failing that, you can go to C:Docs&Settings\<user>\Applic Data\Adobe\Photoshop\6\Adobe PShop Settings\ and delete the file that says something like "Photoshop 6 Prefs.psp"
Jan 29, 2009 | Adobe Photoshop Elements 6: Windows
My clone tool for photoshop elements is not working. Everything else is and has been. I only used it once about a month ago and then it said there was a program error. I didn't need it again until now and...
Photoshop CS
with the clone stamp tool...
try this easy tutorial..
http://www.tutorialized.com/view/tutorial/Remove-Something-From-An-Image/30562
Dec 05, 2007 | Adobe Photoshop CS for PC
Adobe Photoshop CS for PC Logo
119 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
