Question about DCS BFG30BGDL Propane Grill
DCS Propane side burner
We have a DCS propane side burner that burns s rich that it leaves soot on the bottom of our cooking pans. How can this be corrected or how can I troubleshoot the problem?
  • 145 Answers
Hi and welcome to FixYa.
Check the venturi for the burner tube that leads from the control valve to the burner head. We often see where spiders take up residence and create a web and and obstruction right where the air is introduced into the venturi, causing the condition you are seeing. Also check the burner head itself for obstructions and make sure eveerything is clean. Usually air shutter adjustments are "fixed" and do not require adjustments, as these are factory pre-set. If this burner at one time functioned properly and has since degraded, something is interfering with the mixture and adjusting the shutter is not the correct fix. However, if this burner has not functioned propely from day one, there may be some adjustments needed.
I hope this info is useful to you. Please be aware that if you decide to rate my repsponse, "thanks for trying" is actually somewhat negative in nature. I only say this because I have taken the time to type out very detailed responses to people and they come back with a "thanks for trying" rating. The label for that rating is misleading to the customer. It means we didn't do such a good job answering your question.
Thanks for using our service!
Posted on Dec 28, 2008
My stove has a yellow flame and some burners leave soot on pans
perhaps you are using the wrong type gas natural does not burn as hot as Propane .
Jun 16, 2016 | Kitchen Ranges
Why is propane gas range burners leaving soot on pans and now can smell gas.
soot is an indication that the air /gas ratio is too rich
it is adjustable but I strongly advise that a gas fitter do the job
you will need a gas fitter to stop the gas leak
Sep 25, 2015 | Kitchen Ranges
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
I have a Char-Broil vertical propane smoker. The past 3 times I have used it, well, my food has black soot all over it! I have to wipe it all off the food before we can eat it. I have the top vent open and...
The propane burner has a slide opening somewhere before the burner so the gas/air mixture can be adjusted to burn better and hotter. you get alot of soot because the gas is too rich, it needs more air mixed in before the burner. the air vent on top and bottom of the chamber has nothing to do with the gas/air mixture to the burner.
Sep 21, 2011 | Grilling
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
Dec 14, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Sep 11, 2009 | Coleman Grilling
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS BFG30BGDL Propane Grill Logo
107 people viewed this question
Top DCS Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
joel920368
Are you a DCS Grilling Expert? Answer questions, earn points and help others
