Microsoft Xbox Console
Problem for Microsoft Xbox Console
If you leave it paused for too long, it freezes.
By uzir on Apr 25, 2007
If the xbox is idle for more than 45 seconds to a minute it will crash, causing you to lose all unsaved progress. Some games are downright unplayable eg: 'Half Life 2' (which loads the whole map and then you play through the level) so when you enter a new map, it loads the map for a while, and it is as if the game has been idle, and it reports that the disc is dirty or damaged, or just freezes in the loading screen.
It used to not read any discs, but we replaced the dvd player and that fixed it completely for a while. now this is happening. A very annoying problem, to say the least, especially when it locks up while you are saving. Then the file is corrupted and you must restart the game from the beginning. This happened with 'Tony Hawk's Project 8', and 'Burnout: Revenge'.
Solution #1
posted on Aug 17, 2007
Not Rated)
xetas
Rank: Wiz
Rating: 89%, 114 votes
It sounds like a fan may be shutting down within the xbox itself. If the console is under warranty, I would ship it back to microsoft. If it isn't under warranty, try to take off the the top part of the case to see if your woes continue.
**Opening your xbox will void the warranty**
Opening your XBOX Case:
- Use a Torx 20 Screwdriver and remove the screws from the following places on the bottom of your xbox.
-Take off top cover and try again, (Also listen for the sounds of a fan shutting down, or hard drive scratching)
I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox Console
Questions and Unsolved Problems for Microsoft Xbox Console
Do you recommend Microsoft Xbox Console?
Answer
Answer
my xbox has an error and it said wipe it with a soft cloth i done it and it still wont come on
Answer
The screen went green when playing and now says no signal
Answer
hi my xbox has two red bits on the power button and keeps coming up with contact xbox can not play... (More)
Answer
hey i can not create a xbox live with my xbox 360
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
