Question about Whirlpool GH5176XPT microwave Oven
Whirlpool micorwave stopped heating
Whirlpool GH5176xpt-0 just stopped heating. Everything else is working. I read a post about a door switch, is this possible?
  • 1 more comment
  • Anonymous Dec 28, 2008
    Inside light comes on, turntable works, everything is as usual, just does not produce any heat.
  • origjcc Dec 28, 2008
    everything works as normal, however there is no heat what so ever.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    Any error codes on the display?
  • Whirlpool Master
  • 9,098 Answers
It may be a door switch or relay or connection on the main board, but if that were the case, it would be quieter than usual because the high voltage section would not be getting power.
But since you say it's not quieter than usual, I would assume the high voltage section is getting power, so one of these components is probably at fault.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
Posted on Dec 28, 2008
I have a Whirlpool Microwave! It kept saying open/close door. Than everything went out! Nothing works! Is there a fuse or reset button?
Please post the model number of the microwave for more detailed assistance. Sounds like a fuse in the microwave shorted out. Most likely caused by a bad door switch. Recommend replacing all door switches that are there and then replace fuse.
Jan 25, 2017 | Whirlpool Microwave Ovens
Change light bulb microwave
If your owner's manual doesn't cover it, then you will have to do some disassembly, and may have to remove the oven from the wall, depending on the model number, which you did not mention.
But since you posted this is the Whirlpool microwave section, I'll assume that's it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 17, 2013 | Whirlpool GH5176XPT microwave Oven
Have a whirlpool mh7130xez over range micorwave, everything works great but the suface light? beeps when i push the button? tried 3 new bulbs---please help
The relay for the lights is not working. No board level repairs. You will have to replace the control board to get this feature back.
Sep 01, 2009 | Microwave Ovens
Check this link
Dec 06, 2008 | Whirlpool MH7155XM Microwave Oven
Everything works but the heat! Any suggestions?
door micro switch open/need to replace / if that open the magnetron will not power no heat will produce.
Jan 02, 2008 | Whirlpool MH1150XM Convection/Microwave...
Emerson Micorwave oven MW8108P
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya:
Oct 30, 2007 | Emerson MW8108P Microwave Oven
Whirlpool GH5176XPT microwave Oven Logo
140 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
