Question about GE GSH25KGR Side by Side Refrigerator
My freezer is not keeping food frozen
My freezer just recently stopped keeping things frozen. Even though it is on the coldest setting, things are thawing. It just happened out of the blue. The Fridge part is still working great. This was purchased used from an appliance shop that fixes appliances and resells. this was the problem when I purchased it from them but they said it was fixed and it was for about 4-5 months. Now it quit again. They only offered a 30 day warranty. What could be causing my freezer side to not freeze all of a sudden. I already had a problem with my ice maker not making ice properly and overfilling the tray and then spilling water into the bottom of the freezer and freezing. (at least it would freeze then). I was advised by an expert on this site what that problem most likely was and that it was not serviceable. I have learned to just deal with that problem but I really need to have my freezer. I would appreciate any help and advice on this situation. Thanks!!
  • Beth Gunnell Apr 25, 2007
    Also the back of the freezer is all frosted over.
    President:
  • 1,462 Answers
Defrost system is malfunctioning causing build up of ice. remove back panel of freezer, check for ice build up. if so, defrost carefulle with a hairdryer. also check drain is not blocked by ice. if it is, use hot water to get rid of it. (takes time)
Posted on Apr 25, 2007
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Freezer not keeping food frozen, now the
Often times when you set a refer at the coldest setting it just does not work
before giving up on it try setting your control at 4 or 5 and see if that helps
Apr 01, 2010 | Refrigerators
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Hotpoint side by side: CSX20EG 19.6 in our garage. Freezer issue
go to fixitnow.com and ask the appliance samurai!
Jan 20, 2009 | Refrigerators
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
HI MY FREEZER DOOR WAS LEFT OPEN AND THE FOOD HAS DEFROST BUT ALL THE FOOD HAS NOT BEEN OPEN IS IT SAVE TO FREESE IT AGAIN
Nov 26, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
GE GSH25KGR Side by Side Refrigerator Logo
233 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
