Question about Yamaha HTR-6130 Receiver
No sound from the speakers when we use DVD or XBox
We have the Yamaha HTR-6130 AV Receiver. We've hooked it up and it works great with the television. When we want to play the xbos or watch dvd no sound comes from the speakers. What aren't we doing right.
  • 25 Answers
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Posted on Dec 29, 2008
I have hooked up my DTV box via HDMI to my Yamaha. I have hooked up my Xbox via HDMI to my Yamaha. I have Hooked up my Yamaha via HDMI to my Toshiba flat screen. I can get video from all but I am not...
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
Nov 20, 2010 | Yamaha HTR-6130 Receiver
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
How to hook up a xbox 360 console to my yamaha 6130 receiver
You will need an additional HDMI can get them without getting ripped off by purchasing at
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
Apr 01, 2009 | Yamaha HTR-6130 Receiver
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Right rear speaker has no audio
Swap the speaker wire from left rear to right rear if the speaker was from RR now work on LR side this prove the speaker OK then you problem in the receiver
If you swap the RR speaker to LR side and still not work then you
have that RR speaker open
Make sure you hook up speakers cable properly and not short from both terminal speakers and receiver the RED and Black poles
Let me know how you go
Nov 28, 2008 | Yamaha HTR-6130 Receiver
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
155 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
