The remote works with our TV and other DVD player, but the JVC VCR-DVR and the remote are not synching. We have tried all of the possible methods and nothing.
I recomend to read very well your owner manual and read the topis for Synch. see the section a( how to set up b( section troubleshooting.
if you donot have it download from www. retrevo.com
SOURCE: RCA RCU403 3-Device trying to control GPX DVD player???
It may not be able to run the GPX dvd player as GPX is not a mainstream brand, if you have the original GPX remote, you might purchase a learning remote that can copy remote codes from the original, I have seen these Learning Remotes from around $20 by Phillips Magnavox if I remember correctly.
SOURCE: I am in need of the code for an Emerson DVD player
Emerson....................................1004, 1006, 1012, 1026, 1029, 1030, 1033, 1035, 1038,
Emerson................................1046, 1047, 1048, 1049, 1073, 1123, 1162, 1171, 1177, 1179, 1191
SOURCE: Insignia TV code for RCA Universial Remote Control (RCR450)
What about trying a code search with the remote itself.. Turn on your tv, Push and hold the TV button till it blinks, then press and hold then SETUP button while pressing and releasing the PWR button continously till the tv powers off. Once it does that, press PWR again. TV should come on and the code will then stay locked in.. Good luck again
SOURCE: RCA D771 universal remote won't work on Direct TV receiver
You have to use the aux1 button. Which is says in the instruction manual ! I had to do a code search, but works just fine now.
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control.
[^] For future reference,write down each working device
code
OK.
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
applicable, insert media (e.g., cassette or disc).
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
selection, volume, and DVD functions.
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
[5] Aim the remote control at the device and press POWER
OK
CBL/SAT,or TV).
then release SET.
[6] Repeat steps 1 through 5 for each device you want to control.
code
OK.
Have done both of those things several times. Nothing changes.
