Question about PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478 Motherboard
IDE to SATA Adapter
I bought a SATA drive, and discovered that they are different than IDE drives when it showed up. So I bought an IDE to SATA adapter, and when I installed the adapter (which is a small board that plugs into the IDE port on the MB, and then attaches to the SATA drive via a SATA cable that attaches to the small board) the system did not recognize the drive. I tried it in another system (btw, both systems worked, and still do), and it also did not recognize the drive. I took the HD to a computer repair place, and they said the drive works fine. The seller of the adapter won't even answer my emails. I can provide photos, or any other information a layman such as myself might be able to, should you desire more technical information than I have provided herein. I received no other software, programs, drivers, or anything with the adapter, and was told all one needed to do was plug it in. I sure hope you can help, so I can get my unused drive backing up my otherwise vulnerable files which are overflowing from my current IDE drive. Thanks!
  • Valued Customer Apr 25, 2007
    Hi, Thanks for taking the time to help out! I get 'page not found' from that link*.
    The adapter does fit into the IDE slot on the motherboard, and the SATA cable goes from that to the drive. The description from the seller indicated that it would allow SATA drives to work on old IDE motherboards.
    I suppose it's possible they sent the wrong part, but since they have the customer service skills of verminous parasites, it is impossible to ascertain.
    * I found that the link you provided is truncated by this site, by right clicking it and selecting 'copy link text', and then pasting into Google. I went to the accessories page, as I believe you intended. The item there is to connect an IDE drive to a SATA cable - the opposite of what I need. I need to connect a SATA drive to an IDE connector, and that is what the device I bought is supposed to do, but seems not to.
    Brigadier General:
  • 6,966 Answers
Hi, could it be that you have an adapter that works one way only - IDE to SATA - it converts an IDE drive to SATA host port and therefore will not work in your motherboard. What you probably should get is Sata Drive to IDE connector. You might want to have a look @ http://www.satacables.com/html/sata-acessories.html./ Hope this be of some help to you. Good luck.
Posted on Apr 25, 2007
  • Louie  Role
    Louie Role Apr 25, 2007
    I guess you are right, the link being truncated here's the complete link satacables.com/html/IDE_to_SATA_adapter_JM20330.html. Near the end, you'll notice that it says click here for....... is what you need. My intention was to show you how nearly identical the appearances of the adaptors are so that you would have an idea if they send the adaptor by mistake.
    In my case, it took quite a while before Win XP recognized the SATA. The icon New Hardware found showed right up but took really a while before it was recognized as a local hard disk and i was instrcuted to shut down since new drivers have been installed. Might be, I say might be, you need to let you machine take its time in recognizing the SATA and install drivers.
    Also, pls post pix of your mb if able coz the manufacturer's site claims that since version 1.0, they have built-in SATA (pcchips.com.tw/PCCWeb/Products/Productsdetail.aspx?detailid=358&MenuID=16&LanID=0)
    Regards
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
Install sata disk
From what I was able to find it looks like the board is set for IDE Interface connections for the hard drives. But you can make it accept SATA Drives by adapters that plug into the Power Supply cables that go into the hard drive.
I'll show some links below that will show you the adapters you will need.
The link below shows the Cable that would plug into one of the power supply cables and go into the SATA Drive to give it SATA Interface.
http://www.ebay.com/itm/New-4-PIN-IDE-Molex-To-2-X-15-Pin-SATA-Power-Adapter-cable-Fast-From-USA-/270963453066?pt=US_Drive_Cables_dapters&hash=item3f16ae2c8a
The link below shows you the cable you need that will supply the Power to the Sata Drive. It too plugs into one of the cables that come out of the Power Supply and goes into the Sata Drive.
http://www.ebay.com/itm/New-4-PIN-IDE-To-Serial-SATA-Power-Cable-adapter-/270693224712?pt=US_Drive_Cables_dapters&hash=item3f0692d108
May 10, 2012 | Dell 3E851 Motherboard
I bought a Sata/IDE Hard drive Adapter, and no manuel
most h/d dont have a manual,just couple up the ribbon cable checking that the peg in the connector lines up in the socket,fit the 12v/5v cable turn on and windows should see it
Jul 05, 2010 | Computers & Internet
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
I am trying to install a gdr-8164b drive in my inspiron 531 but the connectors are different. How would i go about this, is there an adapter that is available?
your drive is an LG gdr-8164b and is a IDE your computer is using for SATA drive which is different you need to change your drive to a SATA or get a PCI with a IDE
Sep 10, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Bought a Acer 9301 awsmi and its not switching
No, system will not stop working.
SATA and IDE drives have different connectors, so if motherboard is made to take SATA - it takes SATA, if IDE - then it takes IDE.
Also IDE drives are past. SATA drives are much better and works faster.
So there is nothing to worry about.
Mar 28, 2009 | Acer Computers & Internet
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
143 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
AlienWare
AlienWare
frankdanfelt
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
