Question about Samsung HL-T6187S Television
Picture went out on a samsung hl-t6187s
My samsung hl-t6187s is 16 monthsold. While playing WII the picture went dark then out. I unplugged the TV for half an hour and plugged it back in but still no picture. This set has LED lamps that are supposed to last the life of the TV. When I turn it on it looks at first like it wants to light up but then goes dark. Is this common with Samsung? I hope not since I have four other friend that bought this set with my recommendation.
denoles, are you still monitoring this thread? Did you ever find a solution? I have the exact same problem and set.
Posted on May 20, 2010
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, could be anything. Normally, the front panel LED should blink or at least show sign that power is getting inside. Additionally, blinking LEDs would often indicate that the unit has gone into protective mode and the sequence/count of blinks would indicate an error code pointing to probable area of fault. A completely dead or no indicator could possibly be a power supply issue.
This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
Posted on Dec 28, 2008
    Guru:
  • 449 Answers
Try hitting the sides while it's on.
    President:
  • 1,257 Answers
If it is under warranty contact samsung and get it repaired or replaced.
Its good to contact samsung first other than performing any troubleshooting.
Also if you try to get it repair yourself you may lose the warranty..
  • 10,515 Answers
The problem you are describing seems to be a Ballast issue... Does your TV make a clicking noise when the power is pressed? A single "strong" click, or multipple "weak" clicks?
If you would like to replace the ballst in Your HL-S or HL-T series TV (Which includes your HL-S5687W) you can purchase it at the link below for only $66 bux:
http://www.discount-merchant.com/product-p/ballastbp47-00037a_bp47-00033a.htm
Step by step detailed installation guide is available here:
http://guides.fixyourdlp.com/samsung/bp47-00033a.php
When the TV went out, did you hear a whining or screetching noise? The HL-S and HL-T series lamp based projection sets are notorious for failing of the colorwheel... Colorwheel can be found at the below link for $79.99
http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series- p/samsungcolor_wheel_bp96-01579a.htm
Installation guide can be found here:
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
I hope this helps... i don't see anything else that might be wrong with your TV other than the Lamp, ColorWheel, or Ballast...
Please let me know the results.. It's good information for all of us here.............
Thanks.............
  • 10,594 Answers
I think it is time for New Lamp in your TV as existing lamp (bulb) has reached at an end of working hours.
  • Samsung Master
  • 13,433 Answers
Does your set have a warranty? 2 years? 3 years?
I would contact the dealer or samsung for repair service if it is still under the warranty.
If your set is outside of warranty or you wish advice on how to repair the set press the repost button to get more advice from other experts.
Do you have a picture that Identifies the parts on the backside of Samsung TV Model # HL-T6187S ?
you have 1 large one by the lamp, 1 by the DMD pcb to cool the DMD chip , & 1 by the LED ICs(you need to pull the light engine back a bit to see this one)
Nov 20, 2014 | Samsung Televison & Video
My samsung tv model hl-t6187s has no red
The red LED chip has burned out. Samsung purposely overdrives the red LED to make the colors look better and the red one usually fails from heat.
Apr 18, 2014 | Polaroid Televison & Video
My samsung hl-t6187s has no red
More than likely your red led is bad I have this model and I have had to replace it twice in the last four years the part is available online and is fairly easy and quick to replace if you are handy with a screwdriver the actual procedure is available in a video on YouTube for replacing it.
Apr 18, 2014 | Samsung HL-T6187S Television
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
HL-t6187s control problems
Check with Samsung, your model falls under a class action settlement related to power supply issues that your TV may be experiencing. Here is a link to more information about this settlement.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Jul 16, 2012 | Samsung HL-T6187S Television
Samsung HL-T6187S SOUND DROPPING TO 0? By itself
If you can get at the controls again----undo or unsolder the micro switch for volume down! Remove it and see if set works.
A no brainer in that if that switch is bad and vol down still displays nothing else would work
Feb 21, 2012 | Samsung HL-T6187S Television
Tv picture keeps turning off
several things, cooling fan out, bulb going out, lamp ballast or the power supply board could be failing. call 1-800-samsung for nearest service center.
Nov 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hl-T6187S picture goes out
this issue could be caused by a failing power supply and it's not giving enough juice to the proyectors
Apr 03, 2008 | Televison & Video
Samsung HL-T6187S Television Logo
262 people viewed this question
Jerry Greenberg
Jerry Greenberg
