Question about Maytag MER6772 Gemini Electric Kitchen Range
The lower oven locked on its own and will not unlock? How do I get it to unlock?
  • 126 Answers
Have you unplugged the range for 30 minutes.
Posted on Jan 01, 2009
Used the self cleaning cycle 24 hrs. ago, but the oven door will not unlock. We tried to run it through another clean cycle but we recieve an E1 error.
Sorry to read about your problem, I hope this helps you out.
you may have done a panel lock, so try the first solution.
To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Whirlpool RBD245PDS Electric Double Oven
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Oven door is locked and won't open
oven door locked during cleaning then would not unlock after cooling
Jan 19, 2010 | GE JKP86 Electric Double Oven
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
The door is locked
Put the unit back into a clean cycle, wait 2 minutes and then push cancel, the door should unlock
Jan 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Lower over door won't open
The first thing to check is the oven sensor you will have to purchase a new one and have a local service co. come to put it in and unlock the door for you. good luck
Dec 20, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Maytag MER6772 Gemini Electric Kitchen Range Logo
81 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
