I have used my Maxtor One Touch 4 external hard drive for about 4 weeks. I disconnected it from my computer at the office, brought it home and connected it to my laptop: blue light flashes on then off, the H/d spins up but the computer does not recognize a connection. I have a 2nd Maxtor One Touch 4 external hard drive and it works fine. I utilized the same cables and still no connection for #1. Any ideas how to make this work? I have important data that must be recovered.
  • SR22 Dec 28, 2008
    I have tried all of the above and still no light and no connection.
  • SR22 Dec 28, 2008
    I have tried connecting to a desktop also and no luck.
  • 679 Answers
Are the operating systems identicle? Here is the first thing I would look at. Go to "my computer" on your desktop and see if your computer is even recognising the external drive when connected. If it is then its a sotware problem, and at least we narrowed it down. Then if it shows up there right click and go to properties, in there you can do a little troubleshooting with the available tools. I don't want to confuse you so let's just see if the drive shows up in thete, or the device manager, you enter like this Start,Settings, Control panel, Device manager, and hardware, look under drives and see if the removable drive shows up there, Stick with me through tis and we will fix it, Be aware that half a dozen so called experts are going to jump in here now that I gave them a starting point and try to fix your computer wit a single question, or a suggestion that can cause damage, this is an ongoing situation that we are trying to take care of. But I like to do things the right way and that requires feedback from you, I will find you again later after you have checked the things I aske you to, Ok later then, Gym
Posted on Dec 28, 2008
  • 56 Answers
I hope you are using the same platform at both locations. IE windows vista on both machines or windows xp on both. as with anything if they are one and the other they dont like to play together.
start by trying it back at work and be sure it works there. if it does then the format is not compatable with the new machine you are tyring to put it on. Also sometimes there is a file on the machine you started on that sort of locks the data so no one else can steal it. for this you would have to consult the instruction book.
  • 100 Answers
The hard drive must have gone faulty other wise if u say u have tried everything possible it should have worked.
  • 10,515 Answers
Uhmmm.............
Its nothing but Malfunction ( Hard disk Failure )...........
In order to recover data ...............
You should be able to still see these hard drives a "physical drives" when you run a Format Recover.
A lot of these new external hard drives have Fat32 partition. They make them Fat32 and not NTFS becasue if you are running Windows 98 or ME on your computer it means that the external drive can still be seen by your PC (older operating systems do not recognise NTFS).
A "Format Recover" search should recover the entire partition. However if it is Fat 32 you will need to use our new beta version with Fat 32 support. It can be downloaded here:
http://download.getdata.com/RecoverM...-2005-beta.exe
If the scan has already found 2700 files then it has found enough to rebuild the partiton. Whilst the search is in progress, click on the OPTIONS button and go to the FILE TYPES tab, uncheck all the file types so that there are none selected. Click OK and the search will continue, but should run much faster now...
Or if u wanna help :)
http://www.drivecrash.com/Maxtor-Data-Recovery.htm
Thanks.
    President:
  • 2,110 Answers
First check the hard drive in another PC if worked then ur USB port might have some prob.IF not worked in another pc then ur hard drive may have fault..you need to contact the service center...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Since by testing/using the 2nd Maxtor external hard drive on your home PC works, then it has just confirmed that it is the 1st Maxtor that is the issue and not USB port or the cable nor your home PC.
It could be the power supply, or the internal electronics or the hard drive itself inside the 1st Maxtor that may be faulty. To determine, the HD inside the 1st Maktor has to be extracted and connected to an external IDE/SATA to USB adapter. This process then would elminate the possibility of the electronics interface as the culprit. If it works, then the housing/electronics of the 1st Maxtor is faulty. If it still doesnot work with the IDE/SATA to USB adapter, then you have a faulty hard drive.
If the hard drive is deemed faulty, your best bet would be to download, install and run file recovery program. An example of which is GetDataBack.
Good luck and Thank you for using FixYa.
  • 6,487 Answers
If you already tried connecting the drive on a different USB port the next thing that you can do here is to connect the external drive to a different computer it will be better if you will connect it to a desktop and back up all the file if you can access it using a different computer because this drive is going bad already...
  • Mark Gil
    Mark Gil Dec 29, 2008
    Since you already tried connecting the drive to a different computer and still not being recognize this unit requires a service already and Seagate can do that for and they can also try to recover the data inside that drive....
  • 13,433 Answers
Try diffrent usb ports, if possibly try another computer or two.
try this also
turn the pc off
plug in the drive, turn on the computer and see if its detected.
this is just a start so report back with results.
  • Ekse Dec 28, 2008
    does the drive make a sound? clicking possibly? clicking would indicate a problem in the drive.
    there is a normal hard drive inside the usb case if you are outside of warranty you could try removing the hdd from the usb case and connect it directly to the computer. but if the drive is clicking or you hear other odd sounds the drive most likely has a fault that would require service.
    this IS the MAXTOR warranty service
    http://support.seagate.com/customer/warr...
    Seagate = maxtor
I had my Maxtor One Touch plugged in the USB of my computer this am. It has worked fine up to that point. I have 4 years worth of audio files saved on there.... When I went to unplug my Maxtor this am to...
Return or contact Maxtor. For a fee they have the equipment and processes (that are proprietary) to retrieve your data. Do not restore the HD because it will erase ALL information!
Jul 14, 2011 | Maxtor OneTouch III 500GB 7200RPM USB 2.0...
How do I connect the hard drive for Maxtor One touch
Just use a standard USB cable to run from the drive to the computer's USB port, and connect the power adapter from the wall to the drive.
Feb 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I restored my computer and i saved all my data in my one touch 4 mini hard drive. Now my computer wont read one touch 4 mini 250gb. can some one please help me i lost everything?
No, you haven't lost anything. When you restored your software, you only restored the factory stuff. You'll need to reinstall the driver for the external hard drive. After you do that, your external drive and data should be accessible.
Nov 12, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Computers & Internet Logo
21 people viewed this question
Alun Cox
k24674
