Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite refrigerator won't stop making ice
I can't turn the icemaker off because the arm that one must raise to do so is no longer attached on the side toward the front of the freezer section (on the bottom of the refrigerator). Is there a way to reattach it?
Thanks
  • 318 Answers
Sometimes when you pull the shelf in and out, it will bind on the shut off arm and cause it to "pull out" of the i/m module. the arm has to be put back into the back of the module. you can take the i/m out of the freezer or just use a mirror and look for the place the arm goes. it looks like a 1/4", round, white plastic slot. the arm just pushes into the white piece and thats what causes the i/m to shut off when full or when the arm is lifted up.
Posted on Dec 28, 2008
Worked as advertised! Much thanks!
Posted on Apr 11, 2009
How do you turn the ice maker back on?
Posted on Apr 06, 2009
Can't get ice bucket back into place to make ice...what are we doing wrong.
First, turn the icemaker off by raising the wire "bar" that is attached to the icemaker until it clicks into the raised position.
Second, if your freezer has an ice dispenser system, make note of the position of the drive gear at the back of the freezer. It will have two prongs that will need to mate with the icemaker bucket. If they aren't lined up with the icemaker bucket auger, then turn the auger by hand until it will line up with the prongs.
Finally, check for a stray ice cube resting inside the freezer, either on the back wall or on the side rails where the bucket rests.
Oct 03, 2010 | Kenmore Refrigerators
Is there a shut off valve on the ice maker?
There should be a shut off valve at the beginning of the water line that the installer tapped into when installing your icemaker. Mine runs down through my kitchen floor into my laundry room and is tapped into a copper cold waterline with a small handle attached to it.
To stop icemaker from making ice simply raise the lever to the up position that is attached and hangs next to your icemaker tray. This works on most models.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
I need a repair manual for a kenmore automatic icemaker
we always replace the unit we not open it b/c there are very small parts that might get damage its 122$ but if u want to try take the whit cover and open 3 screws then the unit open and the arm can be change make sure u put all together correctly...good luck
Dec 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Too much ice
is the bar the correct one or is it too short? I woulds go to a Parts house and get the opposit bar that you have and replace it first.
Dec 21, 2008 | Refrigerators
Icemaker makes tons of ice and it spills all over the floor
The icemaker should have a thin metal arm that turns it off when the arm is raised, and on when the arm is lowered. This is so when the tub of ice gets full, the cubes push the arm up, and the icemaker is turned off to keep from making excess ice.
When I had the overflowing ice, I checked my icemaker and found that the arm had fallen off (and thus the icemaker won't know when to stop making ice). I found the arm and stuck it back on, and all was well. It may be a bit tricky, and it might take some ingenuity to keep the arm from falling back off.
I hope this helps!
Sep 29, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
414 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
