Question about Omega 1000 Juice Extractor
Heavy vibration and noise
Omega 1000 when i put carrots it starts vibrating very heavily and can not make juice unles after every small piece i clean it
I am using it after 2 yrs when it was new would work great its hardly been used and I am totally frustrated
    Champion:
  • 356 Answers
YOU MAY HAVE CUT THE COVER CHUTE
INCREASING THE GAP BETWEEN THE
BLADE AND CHUTE BOTTOM ALLOWING
LARGER CHUNKS TO PASS THRU. INSPECT
AND IF NEEDED ORDER NEW ONE FROM
OMEGA AT 717 561 1105. ABOUT $15.
Posted on Jun 30, 2009
Juicer vibrates
THE SOLUTION TO VIBRATING. If it spins up ok and starts vibrating suddenly as you are feeling it, here's the solution: feed it very, very, slowly. that's it. i couldnt figure mine out, then realized that if i fed it slowly, it was just fine.
Aug 16, 2013 | Omega 1000 Juice Extractor
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Mar 05, 2011 | Omega 1000 Juice Extractor
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
Feb 08, 2011 | Omega 1000 Juice Extractor
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
My maschine is vibrating alot
Checck for play in the motor shaft , the jar spindle. If so you must remove the shaft to be reset with new bushes so that there is no agitation from the play.
Being high speed a small play can cause a lot of vibration and the spindle must work tight.
Sep 18, 2010 | Omega 1000 Juice Extractor
My Omega 1000 goes off balance and makes a noise like it is going to blow up so I have to end of turning it off. It doesn't do this all the time but it is getting more frequent. This happens with any...
Yours and everyone else's. Best solution is to get a pulp ejecting type juicer.
I have a 21 year old Acme and know how to maintain and adjust it. Even
then I have vibration issues.
Sep 02, 2010 | Omega 1000 Juice Extractor
My juicer spins off of its axis i think, wobbles all over, spinning itself in circles spewing juice everywhere
Omega and Acme juicers will vibrate because pulp
is not ejected during juicing. Only suggestion I can
offer is avoid soft produce and feed as slowly and
as evenly as possible. Been using an Acme for 21
years and did notice a duller worn blade does produce
less vibration.
May 23, 2010 | Omega 1000 Juice Extractor
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
Oct 02, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Vibration
DIFFICULT TO USE. SHOULD HAVE GONE
FOR THE 4000 WHICH EJECTS THE PULP.
SOMETIMES THE BLADE JUMPS UP AND
CUTS THE BOTTOM OF THE CHUTE IN-
CREASING THE GAP BETWEEN THE BLADE
AND CHUTE BOTTOM. INSPECT AND I YOU
NEED A NEW COVER CALL OMEGA AT 717
561 1105.
Oct 01, 2008 | Omega 1000 Juice Extractor
Omega 1000 Juice Extractor Logo
354 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
