Question about DEI Valet Keyless Entry System
Check Engine Alert
Purchased a used 2006 GMC Sierra K1500 HD pick-up which had a Directed Electronics, Automate, AM6, remote starter and keyless entry system installed. Within a month, I got a ''check engine'' alert. My GM dealer diagnosed the alert as ''temporary loss of power to the transmission'' and indicated that the remote starter may be the problem. It just happened again and my dealer wants to remove the system to correct the problem. I like the system and feel that there may be a wiring problem. Is there anything out there indicating that there has been an identified problem with the Automate AM6 and GM products?
  • 344 Answers
No not that I could find, before you remove the whole this just pull both fuses on the main harness red wire there should be 2 total, also check to see that the white ignition wire is hooked up to the remote start unit as this is a very important wire that needs to be hooked up because it is tyed in with your transmission system
Posted on Jan 25, 2010
Engine wont shut off after vehicle started with remote starter
Tools: 10mm torque wrench
Step 1: Find the release bonnet lever or button in the car.
Step 2: once the bonnet is open, locate the battery pack.
Step 3: Then locate the negative charge and unplug the connector to the terminal by using your torque wrench.
Step 4: Then replug it in and close Start the car up and it should work.
Hopefully it works.
Jan 18, 2014 | DEI Python 1400XP Remote Start/Keyless...
We had the Avital 4003 keyless engine starter remote installed on our 4Runner in July when we purchased it. We shipped the car overseas and now that it has arrived the renmote will only start the radio...
You mean the igniton powers up but it does not start, correct? Sounds like the remote starter is not sending power to the starter. Did it ever work? It's possible that one of the 30amp fuses (one that supplies power to the starter output of the remote starter) is blown. If there is 12 volts present, check for voltage at the starter wire (purple) from the remote starter. If it has voltage,make sure it's connected. Also make sure that the harnesses of the remote starter are completely plugged into the module.
Sep 26, 2010 | 4003L Avital 4003 Remote Start Module...
My python remote starter when starting in the morning only wil will runl. On my 2008 dicota truck will run less than a min. And shot itself off only in thr morn.
You need to reprogramme the tach input, the engine is running colder in a morning and will run higher for a few minutes, during the day the engine will be warm and idle quickly.
Nov 21, 2009 | DEI Python 1400XP Remote Start/Keyless...
I just installed the 561r remote starter in my 03 gmc sierra.
CHECK TO SEE IF THERE IS A GROUND OUT WHILE RUNNING OPTION.
Oct 19, 2009 | Directed Dei Valet 561r Remote...
Keyless entry remote quit working. Just purchased new battery. Now Spare remote does not work either.
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Jun 17, 2009 | 2000 GMC Sierra
Purchased used. have remote for keyless remote.
That you need to take it to a car stereo dealer that install NEW keyless entry's...Sorry, thats the easiest way to fix this issue.
Jun 14, 2009 | 1999 GMC Jimmy
94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
Valet 561r remote starter wont start my 2004 gmc sierra
You should not have to... Just start it with a key first.... What are the symptoms, please be more specific..
Jan 16, 2009 | Directed Dei Valet 561r Remote...
DEI Valet Keyless Entry System Logo
175 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
