Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
It is always helpful if you give model and make of the equipment involved. We can be more specific and accurate that way. It si a very straight forward connection and you need two HDMI cables. 1) Connect the Satellite Box's HDMI out to the Receivers HDMI In ( any one of the sockets labeled TV/SAT or Video AUX etc ). 2) Connect the Receiver's HDMI out to the TV's HDMI In. Every thing will work fine except if you switch off the power of some receivers the TV will stop getting HDMI signals ( ie no sound or video if Receiver is Off )
The other way of connecting is to connect the SAT BOX's HDMI cable directly to the TV's HDMI In and if your SAT BOX has a digital Audio out ( Optical or Coaxial ) connect that to the Receivers Digital In. This way you will need only one HDMI cable and one Optic fiber or Coaxial cable. And the advantage is even if the Receiver is Off you can watch video and hear its sound through the TV.
"Component" cable refers to the 3-wire hi-def video connection. It's irrelevant to audio.
Assuming you get all your TV programming through a cable box...
The TV wouldn't actually be a source of audio.
I would advise you to route the Cable Box's BEST DIGITAL audio directly to the Pioneer model number ????? (which would be helpful to know for this conversation).
Run the cable box's normal analog audio to the TV so you can watch it without the Pioneer turned on.
And route the best Cable Video (HDMI, Component?) directly to the TV. Unnecessary paths through the receiver can degrade the signal.
It would help if you use windows 7 ..cause it has the possibility to select the digital out on the sound settings .If you use xp ..you have to open the sound manager and click advanced ..and if it only have the stereo choice t measn the system is not capable to send info in other way ..via hdmi ..and choose stereo ..and select the surround on the tv ..if it is next in line for processing the signal .
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
