Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson sx200 Unable to get this printer to print properly,will only print spasmodically,with gaps in text lines.
Fixed the problem by running several sheets through the printer,emptying the black cartridge(which was where the problem was),and installing a fresh black cartridge.
Posted on Dec 29, 2008
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Unable to print from computer after router was replaced
Hello and Welcome to fixYa!
Please do make sure that the device is turned On, and the device drivers are properly installed and the cable is plugged in properly...Also do make sure that there is no error message at the printer end... Clear that if any....
If you got an error message or something,do tell me...
Best of luck,,
Please do Rate the solution, if found helpful,
Regards.
Jul 13, 2010 | Brother MFC 8840D All-In-One Laser Printer
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Claims new ink cartridge is low...
Hello, at this point I would suggest COMPLETELY uninstall your photo printer, reboot your system and reinstall. Hopefully this helps.
I will tell you though, usually if after running cleaning utilities, the picture still has lines and spaces, could be due to print heads drying up and unable to output the proper amount of ink. This happens alot when people are not using their printer often enough to keep the ink flowing properly.
Recently I had to replace a printer that I had not printed on in like 3 months, the print heads dried up/ clogged up. And the new ink I had just purchased was a waste of money. Had to replace entire printer.
Feb 04, 2009 | Epson PictureMate Photo Printer
Bad print outs.
You could try putting your printer through a few cleans and calibrations. If this doesnt work try changing the ink cartridges, as one may have a damaged printhead
Jan 03, 2009 | HP Officejet 6310 All-In-One InkJet...
All of my text is not printing.
Considering that the problem lessens further down the page, you most likely have a printhead that may be leaking (oozing) ink.
Once the surplus is wiped off on your paper, the ink flow is OK and the leak too slow to continue making the unwanted lines..
Try printing blank documents, you will probably see the lines with or without text printing.
I'm not certain how the printhead can be removed for inspection on that machine but it may need replacement.
Apr 28, 2008 | Lexmark X125 All-In-One InkJet Printer
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
Epson stylus c88 printing issue
It seems this one has been solved by returning it to Epson
Nov 15, 2007 | HP DeskJet 3325 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
231 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
