Question about LG DLE5977 Electric Dryer
Blows cold air and produces little lint in the vent
The dryer is a LG 2532 gas dryer that blows cold air
  • bcruisers Dec 28, 2008
    I am not sure I will ask but it dries sometimes and not others.
  • Dick
    Dick May 11, 2010
    Is the gas valve open?
  • 1,543 Answers
To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
Dyer will not heat
Sounds like an open heating element issue. If you have two sensors for internal temps, the chances of both going bad at same time are remote.
Locate the element wiring and disconnect from circuit and do a simple continuity test. Chances are that it is burnt out or open.
Jan 28, 2014 | LG DLE7177 Dryer
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Newer LG front load gas clothes dryer. power hooked up dryer controls light and operate. gas hooked up and flowing. i hear the igniter light but gas doesnt stay lit. no heat. do i need a special gas dryer...
if you hear the flame light but it doesn't stay on for a long time most likely you have lint blocked up in the dryer or in the vent linepull out the lint screen filter and look down into the duct that the filter slides into,if that's blocked you can try to stick a brush down in there and pull out as much lint as you can and then get a shop vac and set it up to blow and try to blow the rest of the lint out,if this doesn't work you have to pull the front of the dryer off and clean out the duct,also vac and blow out the gas tube and the motor and vac up any lint that's in the cabinet,unplug the dryer,remove the top,then the control panel and then the front panel.put it back together and then go out side and make sure the duct is clear no cage or screen,go back inside,remove the vent line off of the back of dryer,if it's a long run to the outside stick a leaf blower into the vent line and blow it to the outside,put it back together and you should be fine.this should be done once a year with a gas dryer so you don't have any problems with parts or how it's running and most important you won't have a fire.if you need anymore help let me know.
Oct 07, 2013 | LG DLG3788W Gas Dryer
Our Dryer runs but is not expelling heat. How can we fix this issue? The dryer only blows cold air. Thank you
check the vent line if clogged it will cause the sensors to trip off way too soon . that will not allow it too make any heat. check up inside the dryer as well if the vent is way clogged with lint the dryer will too. the vent should be cleaned twice a year
Aug 07, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
No heat, only cold air
if it is still pluged in and running and you only get cold air check your vent hose it may be blocked by lint or you can put the vent off the back and see if you get hot air then if so the vent is cloged with lint if it is still not blowing hot air then you may have a thermostat open this takes a little more checking you have to take the back off the dryer to check the stats try the vent first white
Jan 07, 2011 | Dryers
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
HAve an LG dryer that blows cold air
Does the dryer get warm, or is the heating not coming on at all? Have you tried cleaning your vent leading to the outside, it could be plugged.
Dec 28, 2008 | LG DLE5977 Electric Dryer
Maytag MDG16PR gas dryer produces only warm temperature
you could have a blockage of lint either in the dryers front bulk head (where the lint screen is) or you could have a blockage somewhere in the vent line. check those and if you have a blockage remove it and that should clear up the problem
Oct 20, 2008 | Maytag MDG16PR Gas Commercial Dryer
LG DLE5977 Electric Dryer Logo
141 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
