Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
IONIC BREEZE GP
NO LIGHT NO POWER IONIC BREEZE GP MODEL S1861
  • 6 Answers
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :)
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Jun 21, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
How do you reset a Quadra ,Ionic Breeze
Hi.
This appliance simply resets by disconnecting the power cord for five minutes. The control board does not include battery.
If the model was manufactured before 2007, pleas read below.
Ionic Breeze Concerns
Regards.
Ginko.
Nov 14, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
Regards.
Ginko.
Sep 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
BULB AND BLUE BLINKING LIGHT S1871 AND S1861
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Good Luck!!!
neo
Feb 25, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
My Ionic breez model no: S1861 is not working now. It was working fine last week until 2 days ago, there was no light when I turn it on. Before that, I heard sound buzzing and I've cleaned the grid well....
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Aug 06, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
358 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
