Sometime when i turn on my tv it hisses and gives off a strange smell. Also when i press the volume keys on the tv the menu pops up on screen, when i try to turn off the tv with the remote "Enter secrete code" shows on screen. Once i tried to raise the volume with the remote and got the service menu on screen.
SOURCE: Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
SOURCE: Zenith H2533Y TV Entering Service Mode
wHEN YOU GET THE MENU UP YOU HAVE TO HOLD THE MENU BUTTON DOWN UNTIL THE MENU DISAPPEARS THEN ENTER 9876 ENTER. YOU CAN ALSO JUST AUTO PROGRAM THE SET AND IT WILL COME OUT OF SERVICE MODE.
LADY TECH
SOURCE: ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
SOURCE: Apex 32 inch tv Model #PF3230
G'day mate
Sounds like the power supply regulation has gone high volts, and the screen is blooming because of it. I suggest getting a tech to look at it, will probably have the usual issues of capacitors failing in the power supply. Cheers
regards
robotek
