Question about GE XL1800 1100 Watts Microwave Oven
My GE XL 1800 does everything except heat
The fan and lights work but no longer heats food
    Problem Solver:
  • 17 Answers
This is not something that you can fix yourself. Most likely, the magnetron needs replaced, and this must be done by a service department. So, if the microwave is relatively new and expensive, take it in for service. If it's an old one or relatively cheap model, you would be better off replacing it because the cost of the repair would likely be more than the unit is worth. Hope that this helps.
Posted on Dec 28, 2008
Everything works except the food does not heat up. Any recommendations?
This could be a diode or a capacitor. It is not expensive to fix if you have the time and patience. If you don't then you should take it into someplace to have it repaired.
Apr 24, 2015 | GE Profile Spacemaker XL 1800 36"...
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Adora Spacemaker XL 1800 is no longer heating the food. What do I need to do to replace the microwave emitting bulb?
may be , the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. it need to be replaced .
Jan 11, 2010 | GE Microwave Ovens
No heat coming from Microwave oven-GE Spacemaker Model XL 1800
in the microwave there is a part which produses the heat which will be called as magnetron you check that part.
Aug 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
93 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
