Question about Casio EV-550 2.5 in. Handheld Television
Will my handheld tv work after feb
Is there anything i can do to keep my little casio working after feb. i love it and cannot aford another..
victoria
    Genius:
  • 1,139 Answers
Hello lavillavicto,
Look at you owners manual if the tuner format is ATSC (digital standard) then it's ok, if it is NTSC (analog standard) then it will not work. My experience tells me that the answer to your question is no, because most of these units were made with NTSC tuners. I know this is not what you want to hear but it is the truth.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Posted on Dec 28, 2008
My Casio TV-880 2.3 in. Handheld Television wont get signal, what should i do?
USA Switched to digital signal in 2009 , so basically its bad. if you still want to use , u need a adapter (dunno what its called) im sure you can get 1 by $20 - $100...
Aug 25, 2011 | Casio TV-880 2.3 in. Handheld Television
Casio 970b
First of all, you can get a replacement antenna without too much difficulty. You will just have to match the diameter and tip. Yes the set will stop functioning once the cutover occurs in February 2009. At that time the broadcasts will be fully digital and the analog tuner in your unit will no longer work.
Dan
Apr 02, 2008 | Casio TV-880 2.3 in. Handheld Television
I have a Casio EV-510 Handheld Color TV. Is
The only way is to use a standard "Set top box" or just use it as a video monitor for a VCR or DVD player - It has an A-V input that you can use, but it uses a 3.5mm jack socket (I think) - You'll need to determine the connections, but I'm sure it'll work fine. I'm just researching the conections myself. I'll re-post if I fine 'em.
Nov 17, 2009 | Casio EV-510 Television
Feb 17, 2009 - how can I use casio tv-900?
I just tried mine and i have no signal on the vhf setting but i do get channels on the uhf
Jan 21, 2009 | Casio TV-900 2.3 in. Handheld Television
I have a Casio EV-570 hand held TV. Will this work after the switch over to digital broadcast.
According to CASIO website in Japanese, their portable TVs are not supporting Digital broadcasting and decided to cease production.
Thus it will not receive Digital broadcasting.
Although, EV-570 composite AV Input should still work for Camera, VCR, etc., I have not tried to connect to the DAC box.
My portable DVD without TV tuner worked with DAC box and now can watch digital TV program!
Jan 15, 2009 | Casio EV-570 2.5 in. Handheld Television
Is this portable tv have an ATSC or a NTSC tuner?
Hi!
The Casio TV-880 has an analog tuner, and as such wont be able to receive and decode digital television transmissions. It won't work after February 2009 for American TV transmissions.
Hope this helps!
Nov 14, 2008 | Casio TV-880 2.3 in. Handheld Television
Are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
US Govt Digital Conversion
You will need to hook up a digital TV tuner to the device.
Goto dtv2009.com to request coupons for new tuners if you live in the US.
Nov 10, 2008 | Casio TV-880 2.3 in. Handheld Television
Tv reception on handheld Sony Watchman in Feb 2009
The old Watchmans are analog. If plugged into a digital cable/dish system it will scan in UHF and find the working channel than can be conrolled by your digital remote control. As far as taking it out on its own and working off the external antenna...those days will be over. Sony will have to manufacture digital Watchmans.
Jul 07, 2008 | Sony Watchman FDL-22 2.2 in. Television
Casio EV-550 2.5 in. Handheld Television Logo
592 people viewed this question
Top Casio Televison & Video Experts
Lawrence Oravetz
Brandon Murphy
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
