Question about Hotpoint WMA30 Front Load Washer
Hotpoint aquarius wma30 drum wont turn - Hotpoint WMA30 Front Load Washer
  • nursenightma Jan 19, 2009
    I have a hotpoint aquarius, it is filling up and draining out the water, but it won't spin. Any help would be good. Thanks
  • Hotpoint Master
  • 3,463 Answers
If it has filled with water, and no lights flashing, and then no motor action I would check the brushes in the motor for wear.
Remove rear panel , remove belt, undo 2 screws securing motor,
and lever motor back, disconnect motor plug, noting which way it goes in, and check brushes for wear
Plz rate my solutioin.
Thanks.
Posted on Dec 28, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 31, 2010
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WMA30 is leaking a small amount of oily water from the back of the drum when in use. There is a small hole in the back of the drum, should there be a screw in this hole that has fallen out?
Thwater is leaking because the shaft seal has worn, and the hole is supposed to be there as it is a drainage hole.
The outcome will be that the main drum bearings will eventually fail as the water will get into the drum bearings.
To replace the seal involves a complete strip down of washer. not a job to be undertaken by yourself, unless you know what you are doing.
Nov 14, 2010 | Hotpoint WMA30 Front Load Washer
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma30. Drum not draining water. Have
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Hotpoint Aquarius Wma30, leaking water...filter?
There should be a plastic filter fitted in the hose, if there is not, then it should not stop the pump working, unless ther is a blockage in the hose from the drum to the pump, or a blockage in the hose from the outlet of the pump.Try removing the hose from the pump outlet, and blowing down it to see if is clear.
Also the pump itself could be faulty.
Apr 05, 2010 | Washing Machines
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
481 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
