Question about Lenovo 3000 Y410 Laptop
Error 1311: source file not found:E\LENOVO3000y410 USER GUIDE\VISTA\6.~1.cab , Verify that the file exixts and that you can access it.
Why cant i use Office or word & when i try to reinstall or fix it ?
Somtetimes happens. If your copy is legal, ask your provider
Aug 01, 2014 | Microsoft Office 2010
Adobe reader 8.1.0 Error 1311.Source file not found:C:\Program.Files\Adobe\Reader 8.0\Setup Files \{AC76BA86-7AD7-1033-7B44-A81000000003}\Data1.cab.Verify that the file exists and that you can access it.
it seems that your adobe reader did not installed properly. Uninstall the software and then install the adobe reader again. if the problem still persists then change the installation disc and try with the another fresh copy of adobe reader
May 31, 2011 | Adobe Computers & Internet
Error 1311.sourch file not found.D:\photoshop cs2\adobe(r) photoshop cs2\data1.cab verify that the file exists and that you can accese
that means the cab file which is needed for install the files is corroupt ,damaged or missing you will need the file if not copy the cab file from the cd or try to install the photoshop from the cd
May 28, 2011 | Computers & Internet
On the installing program disc 2, every time i try to download it from the installer cd i get the following message, "error 1311 source file not found f:lpubpro/wizard~4.cab verify that the file...
Computer is incompartible to the media program. Acquire a computer that either recognises the program or acquire a program that would perform on the computer.
Feb 19, 2011 | Nova Development Art Explosion Publisher...
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
Installation failure.Error 1311: Source not found.Verify file exi
http://support.microsoft.com/default.aspx/kb/325076
i hope this helps basicly it sais you might not have enough rights.
there is also a solution in there.
i couldnt find anything else on the error you specified.
Feb 07, 2009 | Microsoft Office Home and Student 2007...
Error message when loading office professional 2007
go to search and search for the file to see where it is located.
Jan 04, 2009 | Microsoft Office Professional 2007 Full...
TRYING TO LOAD oFFICE PROFESSIONAL 2007 AND KEEP GETTING ERROR MESSAGE Error 1311. source file not found:E\SKU0 11.CAB. Verify that the file exists and that you can access it What should I do?
I stil do not have enough information HP model number for the windows (OP) operating system. Your error sound like something missing or curept on thr disk. Is you cd drive E:\   ?   Or is you hard drive E:\  ? Does your cd say that it is compatable with windows 2,000 ?  If not either reload the Xp or obtain the correct version of Office pro.
Do you see any scratches or smudges on the face of the CD? Microsoft can replace these CDs if damaged. Cal them if true.
Error 1311: source file not found:E\LENOVO3000 Y410 USER GUIDE\VISTA\6.LAN\FILES6~1.cab , Verify that the file exists and that you can access it.
The cause of the error is a problem with the Microsoft® Windows® Installer program used by the software. It produces the error when the registry entry AllocateCDRoms at the following subkey is set to a value of 1.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Warning!
Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft has provided a wealth of critical information you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined in ARTICLE-ID: Q132332 "How to Back Up the Registry" in the Microsoft Knowledge Base. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Start the Registry Editor and locate the following subkey:
goto start->run and type regedit to start registry editor
Change the value for the AllocateCDRoms entry to 0.
Exit the Registry Editor.
Dec 28, 2008 | Lenovo 3000 Y410 Laptop
Lenovo 3000 Y410 Laptop Logo
61 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
