Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
Configuring 2300 Wireless Broadband Router with new HP Pavilion
I am having trouble setting up my new HP Pavilion Computer (64 bit) with the Dell 2300 Wireless Broadband Router I used with my previous computer (Dell Inspiron). Is it compatible?
    Scholar:
  • 135 Answers
Yes.
Just ensure you configure your new HP pc with the same security code and password you used on your old Dell.
Posted on Mar 04, 2009
Where is the wps button
some routers dont have wps button but if you need to reset router To restart the Dell TrueMobile 2300 Wireless Broadband Router, unplug the power connector and plug it back in.
To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Jan 06, 2013 | Dell TrueMobile 2300 Wireless Broadband...
I want to re-install my wireless router #2300 after my cable company installed a new modem
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the router
ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 24, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Windows 7 Pro 64 Bit and No Internet
It sounds to me like you need a new driver for the LAN adapter that is compatible with Windows 7 64 bit. Right click on Computer under the start menu, chose manage, and open the Device Manager applet. Look for your network card under Network adapters. Right click on your adapter and click on properties. Go to the driver tab and click on update driver. You can also try uninstalling the driver from there and then have the computer scan of new hardware from the device manager screen and let Windows reinstall the driver. Let me know what you find so I can help you further troubleshoot if this does not fix the problem.
Jan 08, 2010 | HP Pavilion a1600n (882780776265) PC...
Need to change the security code for my dell true mobile 2300
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 17, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
192.168.2.1
Click the Go button.
You are prompted for a Username and Password.
Type the following as your username:
admin
Type the following as your password:
admin
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Click the Save and Restart button.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address 192.168.2.1.
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Pc can't find 2wire system
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Aug 28, 2008 | 2wire (1000-400108-001) Router
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
290 people viewed this question
Alun Cox
