Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool ultimate care II tub has a flat spot while spinning
It seems to only be when it starts braking(slowing) that it goes thump thumps etc. and when it is done. if you spin the tub, by hand, there is a spot that it thumps. It is the same spot, like there is a catch or something. It can be VERY loud when the machine is running. Please advise. Thanks, my head is spinning.
  • 318 Answers
This sounds like you have a worn tub drive block. you will have to remove the cabinet and then the tub cover, agitator and then tub nut. the nut is large and has a special spanner wrench to remove it, but you might be able to remove the nut with a large pliers or pipe wrench. the nut is cheap, usually about 7-10 bucks, but it is hard to get to and it will ruin the basket drive shaft if you let it go too long. so best to fix as soon as you can or it will cost alot more to replace both the block and the basket drive.
Posted on Dec 29, 2008
Thumping sound without spin
You can check the belt, pulley, and the motor
Feb 01, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Thumping at the end of spin cycle
Possibly your tub drive hub is stripped. I'd check that first. Look at this video.
Oct 25, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
During deceleration after spin cycle there is a loud thump,thump every 180 degrees of tub rotation.Can i easily repair this and what are the estimated parts cost?
I assume that you have checked how the machine is loaded. My experience tells me that if the load is uneven the thumping begins. If the load is even I assume that a washing machine repair shop is the place to ask, after you have consulted the manual.
Jun 13, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet won't drain, won't spin and makes a light thumping noise
can help but need to know a few things first in drain do you hear any thing running and turn it back to wash and see what happens don't rate me till were done un less you just want to give me my four boxes lol
Jan 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ8220HQ0
You have to start eliminating them one by one a common reason is the spin tub mounting block if the motor comes on and clutch is driving basket drive and brake assembly than this is the problem.
Oct 04, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal De
