F 20 flashing on kenmore HE washer this morning
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
F-20 is flashing on our HE plus 2 front loader washing machine
Whirlpool (Kenmore) 'F16, 18, 20, 21 and 22' all refer to 'control unit failure I'm afraid ;-0(
Sounds like a service call is required, sorry.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 24, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What is the F 20 flashing warning light for on a kenmore elite washer
F20 = "Communication failure between EOC and ESEC system. Recommended action: Test harness/connections P4 (EOC) & P11 (Surface Element Control Board). If harness checks OK, failure can be caused by faulty UIB, surface element control board, or EOC."
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
Washer stop and flashes 20 F
this sounds like the hose to drain is cloged or the pump is blocked up in back of washer were drain hose is at remove back the hose that drains from tub to drain needs to be checked remove clamps and flush hoses,than look in pump and remove debri,and put back together take cloths out and sanitize machine remember use bleach and hot water or use pool shock a eighth of a cup and add in detergent desp. and let it sit his well be more powerful and get rid of meldew,i hope this helps
Dec 22, 2009 | Kenmore HE3T Washer
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
F-20 fault
be sure pump is cleaned out
Oct 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
