Question about HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one printer will not print excell 2007
I get a print out with only empty cell when printing excell 2007
where as forr printing words there no problem at all.
I have already spent days trying.
Please help. Thank you very much in advance.
  • 67 Answers
Did you look at the page break view. It's under view on the menu bar. Make sure it's adjusted properly.
Posted on Feb 25, 2009
How do I use Excel to pring labels with the Zebra LP2844?
I'm going to assume you can already print from the computer to the Zebra. I am also going to assume that since you have Excel, you also have Word. The first thing you need to do is layout the labels in Word. I cannot be more specific because I have no idea what size labels you are using.
Create and print labels
Next you need to merge the values from Excel into Word
Mail merge using an Excel spreadsheet
Here are some videos that might help
Mail merge Word
Feb 16, 2017 | Zebra Office Equipment & Supplies
I created a document in Word 2007 and saved it on a flash drive. I brought it up in word 2010 to make some changes and print it out. When I went to print it it printed only one letter per line in th
If you are able to create and print new documents in Word 2010 then I would not do anything to the Word 2010 installation. However, if the problem is with printing only then it might be best to check of the printer driver installed on the Word 2010 computer is working ok. Also try a Print Preview before you print to see how it looks on the PC screen.
Otherwise it may be simply a compatibility issue of the document created in Word 2007. Open it in Word 2010 and save as a new file. Then open the new file and do a Print preview before printing.
Aug 21, 2014 | Microsoft Office 2010 Home And Student...
My printer will not print Excel worksheets, charts, or Access tables. It will only print Word documents from the XP,2003 computers in my class. It prints fine from my new computer Vista, 2007. What can I...
Try to do a print preview from excel.
What you see is what you should get since word is working properly.
If the print preview is leaving stuff out, you need to modify the page layout in page setup
Mar 24, 2010 | Brother HL 5170DN Laser Printer
I am typing in MS Word 2007 with MathType 6.0. I
Hi.
When you click quick print from the MS Word 2007, usually it will go to MS One Note 2007. I have tried printing from the Word and it was successfull. Perhaps, if that doesn't work going to quick print, try to pass through print preview and make some adjustments on the printing setup and set your printer on default mode.
I hope I have helped you with this.
Blessings.
Feb 03, 2010 | Microsoft Office Word 2007 Upgrade Version...
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
I have several address stored in Excel. Now I
You don't need to print labels in Excel. You can use the mail merge feature in Word to do so. Use the Excel file as the data.
Nov 06, 2009 | Microsoft Excel for PC
How do you print envelopes?
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007. From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printing 2003 excel documents with excel 2007 student edition
In the view tab make sure your page break preview is set correctly.
Aug 24, 2008 | Computers & Internet
Unable to print from word 2007
you are going to have to UNINSTALL all of office first and even the LOCKED version of word.
The locked version of word will not allow you to print.
Also after uninstalling office and the locked version of words, then you reboot, then reinstall office 2007 ONLY!
do not download the locked version of words.
if you want to try uninstalling the locked version of word first and see if it works, if not you gong to have to uninstall everything that has office!
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 05, 2008 | Microsoft Office Professional 2007 Full...
Ms word 2007 docs print every other line
This seems like a print driver problem. You may have to get an updated driver for your printer for Msoffice 2007.
Sean
Nov 30, 2007 | Microsoft Office Professional 2007 Full...
HP PSC 1210 All-In-One InkJet Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
