Question about Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore 665.1736 fills with water but does not spray
Kenmore dishwasher does not spray. I can hear the motor turn on, but no water is being pumped into dishwasher.
Take thre drain hose off from disposal. Pour hot water down the hose until full. Cover end with hand. Press cancel/drain while holding hand over hose - over bucket. That may unstick checkvalve balls and or fix air lock. I have to do that every 6 months or so. Started happening 1 month out of warranty. Go figure. Not a fix - just a work-around...
Posted on Jan 17, 2009
  • MrWasher99 Jan 17, 2009
    Sorry - wrong thread....
Breaker at dishwasher trips right after water has filled.Spray arm has not turned.
There is an electrical short circuit, check/reverse the leads going to the pump or heater.. Sounds like controls and water valve are fine. If wires are not connected to the correct locations you need a new motor because it is internal.
Aug 26, 2012 | Kenmore 665
Kenmore 17379 dishes are not clean after running a cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore washing machine fills with water but will not wash..it sounds like its doing something then it stops after a while i hear it drain and then stops again..water doesnt spray..I let the dishwasher...
Often these work by reversing the motor which has two pump impellers. One direction will pump the water out and the other will pump it through the spray bar. IF the one pump impeller has broken then that would explain your symptoms.
If this is the type you have, verify that the motor is running reversed from when it is draining. If it is not running during wash time, then the timer is probably at fault. If it is running, check for broken pump impeller for the was direction.
Sep 29, 2009 | Kenmore 24 in. 16193 Stainless Steel...
Fills with water, hums, does not spray water, Kenmore model 17532
The motor is blocked. Try taking off the kick plate and when you hear the hum, move the impeller blades with a screw driver to jump it into gear. If you can't get it going, you'll need a new motor, but this is a pain to install.
Jul 12, 2009 | Kenmore 24 in. 17532 Built-in Dishwasher
Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
May 28, 2009 | Kenmore 17459 Free-standing Dishwasher
Dishwasher - no spray arm action
I also had this problem and it turned out to be a small piece of a drinking glass that had made it all the way to the chopper and wedged between the blade and the housing. I was able to do all of the work from inside the dishwasher without disconnecting anything.
Feb 15, 2008 | Dishwashers
Dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Jul 19, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 16039 Built-in Dishwasher Logo
356 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
