Question about Refrigerators
GE Americana freezer is not defrosting
I have frost building up on my GE side by side model A4425GDTAWW. Is there a place where I can buy/download the service manual that shows how to do diagnostics for this model?
  • Anonymous Apr 10, 2009
    my freezer is not defrosting model GTS22IBMWW
  • 306 Answers
Try this web site. might be just books on all units not brand specific.
Appliance Repair Books and Manuals
Posted on Dec 28, 2008
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer defrosts, things melt then frost up
You have a defrost system failure. You can verify this by take off the rear shield of the freezer and looking at your evaporator coil. If it has a large amount of ice built up on it, then your defrost circuit is not functioning. The defrost circuit is made up of the heater (WR51X10055), the defrost thermostat (WR50X10068) that are located in the freezer section close to the evaporator coils and a timing circuit that is part of the main control board (WR55X10942) which is located in your component compartment at the lower rear.
NOTE: If you defrost the evaporator coils the refrigerator should operator normally for about two weeks (until the ice builds back up).
Hope this helps! Hal aka ImJustAvg
Jan 01, 2012 | GE Americana A4425GDTWW Side by Side...
GE Side by Side, Frost Free, model TFF19DWB, frost beginning to build up in the freezer, freezer not freezing, and fridge not cooling enough.
You have bad defrost heater. Remove the back wall of the freezer and use ahir dryer to melt all of the ice from the coils. Replace the heater that is at the bottom of the coils and you will be good to go. Should be able to get the heater from any appliance parts store. Melting the ice off the evaporators will buy you about 5 days of cooling which should give plenty of time to get the heater changed. Good luck and hope this helps.
Mar 19, 2010 | GE Refrigerators
Frost builds up in freezer compartment. The freezer coil is clogged with frost/ice
not knowing the model number
i would venture to guess there is a problem
wiith you defrost system
that includes
heater
terminator
timer
Oct 08, 2009 | GE GSS25JFM Side by Side Refrigerator
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Apr 06, 2009 | GE Refrigerators
Refrigerators Logo
283 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
