Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Spark plug gap for AP3923 in DeVILBIS generator
What is the gap for an Autolite AP3923 spark plug in a Briggs & Stratton 19E412-1131-E1 engine on a DeVILBIS GB5000 portable generator? (I cannot locate my manual since we moved and cannot find it online either.)
Thanks.
Robert
  • 1 more comment
  • yantisr Dec 28, 2008
    Solved. Found the manual at Briggs & Stratton's web site - it is for the 19000-25000 Series engines. (doh!) The gap is 0.030" (0.76 mm).
    But thanks for this site anyway. I will surely be making use of it in the future.
    Robert
  • yantisr Jan 28, 2009
    mrfixit-jerr,
    As I said in my 2nd post on Dec 28 '08:
    (I) "Solved." (it myself) "Found the manual at Briggs & Stratton's web site - it is for the 19000-25000 Series engines. (doh!) The gap is 0.030" (0.76 mm).
    Robert"
    Thanks for the followup though.
    Robert
  • 54generator
    54generator May 11, 2010
    Send me the engine model number & I'll reply with the plug gap. The model number is 5-6 digits long and located on one of the engine's metal shrouds.
  • 15 Answers
SOURCE: cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Posted on Apr 23, 2009
panilling9
  • 284 Answers
SOURCE: briggs & stratton 28u707 1112-e1 repair manual
go to partstree.com
find briggs &stratton
or to the left of the screen enter your number you gave
Posted on Jun 21, 2009
  • 58 Answers
SOURCE: I just got a used Briggs & Stratton 8550/5550
here is the link that you can view and print the owners manual from...
http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=030253_0EFS1CS_LO.pdf
please rate this answer if it helps..... :)
Posted on Sep 24, 2009
  • 302 Answers
SOURCE: what is the gap setting for RJ19LM spark plugs for
mine calls for .035
Posted on Dec 02, 2009
Testimonial: "Your information that I asked for was right on the money but took to long. I ended up doing some more resurch to find the answer sooner. thanks anyway"
  • 20 Answers
SOURCE: need to reset manual governor on 10 hp briggs and
First loosen the pinch bolt and nut on the govener arm at the governor shaft. To set the governor make note of the governor arm to open the thottle wide open. Hold the governer arm to where the throttle is wide open then turn the governor shaft that is coming out of the engine block in the same direction until it stops then tighen the pinch bolt and nut on the governor arm to hold the arm in position on the governor shaft. Make sure when you start the engine you don't over rev it. Start it in low speed and move up slowly. You may need to reset the spring tension.
Posted on Jan 18, 2010
What should the spark plug gap for magneto be on an autolite 216
I see anywhere from .030" (.76mm) - .035".. the smaller gap will be easier for the magneto to fire...and probably run better at low speeds..
Sep 23, 2017 | Garden
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Oil coming from valve cover
did you gap spark plug to.028" ? may need to replace the valve cover gasket.
May 24, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Spark plug gap for a rc12yc on 22 hp engine
Gap setting for a Champion RC12YC spark plug is .030
Apr 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
1o h.p. generator, starts fine, runs good for short periods then kind of sputters, a single sputter, but every second or so and will run like that for hours, thought running would help, didn't.
I realize you have a 10 Hp Briggs engine. The symtom your describing is often caused by the valve lash gap being to narrow on the EXHAUST valve. You may have a 0.001 gap cold but when it warms up that gap is less and you get just a bit of compression blow by but not enough to impede power output. Over time it will usually get harder and harder to start. The remedy is to reset the valve tappet gap
Depending on what engine you have the GN series the gap for intake and exhaust is 0.002 with the flywheel directly at TDC.
Standard OHV Briggs are adjusted with the flywheel 1/4 inch past TDC to a gap of .004 - .006.
The Jam nuts are torqued 65 - 85 inch lbs
Non OHV engines L-head are adjusted .004 intake and .006 Exhaust at TDC by changing valve stem length with a grinder or replacing the valve if necessary.
If you still have the problem after doing the above... replace the spark Plug... (again even if yours is new) After spark plug replacement you still have the problem respond here and I will help you until this is resolved.
This could also be a case of the fuel mixture just a tad lean..
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Briggs & Stratton Briggs Stratton 6200...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
488 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
