Question about NEC NR 7900A (NR7900) CD-RW Burner
Wont recognize burned disks
MY NEC NR 7900A CD-RW Burner cd rom will not recognize disks that have be rewritten (burned). It will recognize audio cd's that I have for example bought in a record shop. When i placed a burned cd into the cd room it makes noises as if its recognizing the cd then abruptly makes a *click" sound..it repeatedly does this...unti a point when I guess it marks the cd as unreadable. Is this a device defect? My comp is a dell inspiron, approx 6 years old.
  • 661 Answers
This does sound like a defective drive, most likely a laser / reader issue, because the refractive properties of the CDR is different from a "pressed" disk it looks like thia failed TOC seek issue, the head starts at the center of the disk and reads outwards, the click noise is most likeley the head reaching the terminus (the outer limit of the motorised movement), the drive then unable to find the TOC gives up and decides the disk is unreadable. if this drive is within the manufacturer's Warrantee period I would reccommend sending it back.
Posted on Aug 01, 2007
SOURCE:
Will this burn dvd
No, it will only burn CD's. You need a DVD-RW/DVD-R burner.
Jan 24, 2011 | NEC NR 7900A (NR7900) CD-RW Burner
Can I burn DVD ?
No. If you have a CD-writer, you cannot burn onto a DVD-disk.
Jul 31, 2010 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
CD-Rom drive missing
Go to this webpage and you will be able to solve the problem. http://support.microsoft.com/kb/314060#letmefixit Basicallly, you'll be resetting the registry to recognize your CD ROM again. Be SURE TO FOLLOW STEP BY STEP. Print the instructions first so that you don't lose your place.
Apr 09, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
Write to CD
Hi.
This is common. It usually means the laser diode is too weak to burn the layer on the disc, or the lens has lost it's clarity. This means the optical pickup assembly requires replacement. Probably time to replace the drive.
Mark
Oct 25, 2008 | NEC NR 7900A (NR7900) CD-RW Burner
I have a NEC NR 7900A music burner that came with my dell
It Sounds like you need a CODEC, to DECode the movie, so that it will burn it. Try this: goto http://www.dvd43.com download the decrypter. Install it, and you should be able to burn most, if not all the newer DVD's.
Let me know if this does not work for you. If that happens, let me know what version of Windows you are using
Dec 20, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
My NEC NR 7900A burner will not burn music cd's or photos
i try to burn music from my libery with but i get a massege that says i need to instole my cd burner can you help me with this
Oct 31, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
NEC NR 7900A (NR7900) CD-RW Burner Logo
136 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
