Question about Welding Tools
Dirty weld Sir, I have been tig welding for 38 years and this is the second syncrowave 250 I have had that after a few years has started doing the same thing. I took the other one to a Miller factory sales/service facility a number of times, they sent a technician to my shop to see if maybe there was something there to cause the problem but finally they gave up, they couldn't fix it. I bought another one and now have the same problem. I think it is a printed circuit problem. I have an L-Teck squarewave 250hp tig welder that I have had for 15 years and still works like new, also a Esab tig 250 and a Lincoln275 tig that work fine, so there isn" a problem with the power supply and I have changed bottles, torches, cups, tungsten and everything else to no avail. I'll be buying another welder if I can't fix this one and it won't be a Miller syncrowave 250. Thanks for your response, Marv.
  • howardroark May 11, 2010
    Thanks, Marv. I'm sure at this point you are right!
    Problem Solver:
  • 5 Answers
What kind of problems you haveing with your it the board you talking about.are the hf .droping out not comeing on .i work on millers and a lot of syncrowaves 250.if you can be a littal more specific i will try to help you scott
Posted on Sep 15, 2009
Clean your metal with a good peace of the green scotch guard scrub pad prior to the weld.Also try turning up your gas and move a little faster when using filler wire,rember to much heat causes a darker dirter weld.hope this helps
Posted on Feb 08, 2009
I have a Miller Syncrowave 250 DX and it has 3 fans, 1 come on as soon as machine comes on and after welding for about 10min the other 2 come on but they are not
Do you mean to say that the other 2 should come on, but are not? Perhaps you are welding using lower settings than before, and the machine just isn't heating up as quickly. Is there a point at which the fans do come on? Say thirty minutes into the job instead of ten? Maybe you were afraid to run it too long without the cooling fans on and so stopped prematurely, before the thermostat turned them on? Check fuses and breakers.
Sep 01, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I have a miller sycrowave 250DX i have been tig welding for about 10 years i bought this machine 2nd hand hoping it would work ok when i weld in AC and hq the arc seems like it just wants to stop it...
Did the machine ever work properly? I am assuming you are using a remote for tig welding. If you watch the points, does the HF stay on after the 5 to 10 seconds as you stated. It should stay on as long as you activate the machine. Make sure your Start Mode is in continuous. See page 42. Since there are so many options, check page 34 for help setting the options. If you still cannot get ti to weld properly, contact Miller for service.
Aug 29, 2017 | Miller Electric Manufacturing Electric...
How much to charge hourly for TIG welding
If its a lot of welding and your machine, charge, 25 to 35 dollars an hour i have small jobs i charge from 10 to 50.00 for by the job just depends, thats about what the market will bear rt now people dont have money
Feb 17, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Syncrowave 250 dx aluminum set up
You can go to and download the manual for this should help you
Dec 13, 2009 | Miller Electric Manufacturing Electric...
I could not welding aluminium with Syncrowave 250DX. could you advise me on what's been missed ?
Gas, tungsten shaping,tungsten protrusion, Typeof gas grounding, gas pressure. setting on AC .
Oct 08, 2009 | Miller Electric Manufacturing Electric...
Syncrowave 180 sd. I was welding when it shut
Sounds like a bad thermister on the rectifier or a bad control board.
Aug 12, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Tig my pudle melts into gray not shinny
Ensure you have the correct angle when using the torch = 22-24 degrees from vert: this will provide good gas coverage. setting should be 15 - 20 ltrs using a "flow meter".clean the material thoroghly then weld , dont clean then leave for a long time.
Argon gas sometimes can be contaminated and cause heavy soot on the weld bead,
TIG electrode should be Zirconiated with a rounded end not pointed.
Use forehand ,method
Feb 02, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
369 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
