Question about Vivitar ViviCam 3710 Digital Camera
How do i take video clips
L can use this as a camera but have no manual l made 1 video but have no idea how
    President:
  • Vivitar Master
  • 1,734 Answers
Find a user manual for download here:
http://manualfox.com/link/vivitar.htm
Posted on Apr 07, 2009
No matter the size of the chip 4GB or 16GB...I only get 10 minutes of recording time
What make and model camera? Ten minutes total recording time or ten minutes per clip?
There are two possible reasons why the clip length may be limited.
1) Some cameras limit the file size of any one video clip. Try reducing the resolution and see whether you can record longer.
2) In some parts of the world video cameras are taxed at a higher rate than still cameras. By limiting the length of a video clip, it's possible to avoid having a camera classified as a video camera.
For further details and limits, see your manual. If you require further assistance, please add a comment to this question and specify the make and model of your camera.
Dec 03, 2014 | Cameras
Videos stop recording prematurely
Use a lower resolution. According to page 36 of the manual, you can record up to 4GB in a single clip, and 4GB will hold about 11 minutes of full HD video.
Mar 17, 2012 | Samsung PL210 Digital Camera
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Want to save video clips to a DVD.
can you view the camera on the movie maker?have you selected the correct source in the options set up?go to capture from video device and select your device .good luck farr64
May 03, 2009 | Nikon COOLPIX S60 Digital Camera
HOW TO DO A VIDEO CLIP
Make sure your camera has video capability.
Access the options menu and see if you can set it to record with audio.
Click the shutter once to record, click it again to end the recording.
Setting a timer may be a good idea too.
Once youre done, upload them onto your computer, and you're done.
Is editing needed?
Apr 10, 2009 | Samsung Digimax S730 Digital Camera
I want to take a digital camera video clip and put it onto a flash drive. The clip is approxiamately 10 minutes. Will it fit onto a 1 GB flash, or even less? I hope this is the sort of question that is...
The amount of memory required depends on the amount of compression. 1 GB is good enough for about 25 minutes
of a premium quality DVD movie, and several house of
reasonable quality mpeg video
In terms of short video clips from an hand held digital mini
camera, the 1 GB Flash card is plenty, providing the camera
uses an efficient compression algorithm.
Martin
PS
I believe the website will send you an email, when the question
is answered, providing you have registered properly
Apr 24, 2008 | Computers & Internet
No sound on video clips
On most digital cameras of this variety (but not all), the video recording is more of an add-on feature and not its main function. The video clip is actually a series of still pictures taken continuously to give semblance of video. For this reason the video clips is a couple of seconds at most. In the same token, there is no feature for audio recording (no mic, no electronics) hence the playback is absent of sound.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Polaroid PDC 5070 Digital Camera
Panasonic Lumix DMC TZ3
Use your USB cable or a Card Reader. Read your manual to insert Date on pictures. Note date will show on pic and cannot be removed.
Best idea is to downloand you pics asap and change each pic file name to embed date taken in filename, not on the pic itself.
I recomment the San Disk MobileMate SD+ miniature Card Reader for SD and MicroSD card reading. Just a little larger than a Flash Thumb Drive. Saves lugging around a USB camera cable and saves your camera power otherwise needed to power a download via a USB cable. About $15 at RadioShack, Staples, etc retail stores selling cameras.
Jan 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Downloading video clips
i lost the cd and now i cannot download vidio clips
Jan 01, 2008 | Jazz DV-179 Digital Camera
Vivitar ViviCam 3710 Digital Camera Logo
50 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
