Question about Bose Wave Radio
Bose 5disc changer trys to pick up any disc just makes noise of motor running, sat not used for year.
I called bose,they sent me e-mail info send around $85 and the unit,they send a new unit. no repairs not bad I guess. Open one up if you get the chance, thats why no repairs! Enjoy-- d.g.d.
Posted on Jan 06, 2009
BOSE WAVE MUSIC SYSTEM PLAYS CD BUT DOES NOT TURN OFF
It is probable that the battery will need to be changed, this the first step to find out if additional work is required.
May 17, 2012 | Bose Wave music system with multi-CD...
It won't play disks and just makes a lot of mechanical noises as it goes from disk to disk trying to play one.
The mechanical parts are working but the laser pickup assembly is not reading the disc. The possible causes are, dirty laser pickup lens, bad pladder motor, or no b+ to the motor, or worn out laser assembly system. Because of the expense of buying the Bose units I highly recommend a professional service man to work on the item.
Dec 28, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
My bose wave multi cd player will not play discs, error code comes up. Only 1 year old.
hi,
may be some mechanical problem or laser pick up unit have some problem. is better u should replace the same, for maintaining the audio quality.
ok
Dec 17, 2010 | Bose Wave music system Multi-CD Changer...
Cd's not playing even though amber light is on so it recognises the disc is in. Followed all the procedures in the manual, tried disconnecting and re connecting power, tried using different discs.
Hi
Im afraid it sounds like the Optical pick up has failed you will need to have it serviced, i beleive that Bose have a fixed price repair service, if you take your unit into your nearest bose dealer they will return it for you
regards
TechSupp12
Dec 12, 2010 | Bose Wave music system Multi-CD Changer...
When using my 5disc cd player it keeps skipping and causing static intermitingly.The cd's are new and play fine on my small BOSE with only one cd unit.What do I do??? ngly
First thing I'd try is cleaning the laser with a CD / DVD lens cleaning disc. You can find them just about anywhere (Walmart, Target, Best Buy)
Just follow the instructions on the disc (basically just play it) the disc has brushes built into the bottom which will clean the laser lens automatically.
Let me know if that clears up the problem.
--RescueTechLA
Dec 02, 2009 | Bose Wave Radio
2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
May 21, 2009 | 2007 Nissan Maxima 3.5 Sl Sedan
Bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
Jun 30, 2008 | Audio Players & Recorders
Bose Wave Radio Logo
49 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
