Was working, then it wasn't. New batteries. Wasn't dropped or damaged. Just non-responsive. No display, no power.
SOURCE: I take my pics front
1. Try to reset you camera
2. Clean your camera lens with microfibra clothes
SOURCE: I recieved a brand new
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
SOURCE: I have a new EOS
That sounds like an issue with the memory card. Yes you will lose all current photos on it when you format the memory card. It's also safe to leave the battery in the camera as DSLRs don't drain power when the camera isn't in use.
Testimonial: "thanks!"
SOURCE: Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
