Question about SanDisk Sansa e250 MP3 Player
Half of my songs can't be played
Okay I had a friend who borrowed my sansa for about a week and when he borught it back it went into a freeze, and i had to hold the menu/start button to turn it off (the screen froze as it played music). However as the music stopped and the screen went black; I turned it back on. It went into a "Referesh Database", however at the end of it only half of my songs were playable, the rest were appeared to have been messed up somehow and they can't be played because everytie i try to play them it just says "Bad Track". I dunno I am currently using a Windows Me, the XP I have in my house lost Internet access about a month ago and I still have to wait for the Internet to be setup from my ISP in order to fix it myself. But for the meantime is there a way I can reset or undo the 'Refresh Database' thing so all of my songs can be playable and my data can be fixed. Plus it's been a week now and I still cant find any way.
    Scholar:
  • 47 Answers
Hi. Seems like some of your music files somehow got corrupted, and might be the cause of the "Refresh Database" error. Normally the best solution would be to re-apply or update the firmware using the SanDisk Firmware Updater on this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 But since you said that you're still in the process of setting up your Internet, may I suggest you set your E250 to MSC mode and perform a "Low Level" format. Here's how: (1) Set your player to MSC mode by navigating the Menu as follows: Menu > Settings > USB Mode > ..select MSC (2) Plug your E250 to your computer (are you using Windows XP or ME?). Your Operating System should recognize the player as a "Removable Disk" and will be assigned a drive letter. (3) Right-click on the drive letter corresponding to your Sansa E250, then select "Format" (4) When the Format window appears, make sure that the file system type is set to "FAT32", and that the "Quick Format" checkbox at the bottom of the window remains un-checked. Click "Start" to begin the process and follow the on-screen prompts. Formatting the player, though, will erase all your files but will clear the player of any corruption. Make a back up if you wish before formatting. (5) Unplug your player and switch the mode back to MTP if you like. MTP is used for subscription songs while MSC is generally used for non-licensed songs (like songs from Limewire, songs ripped from CD's, etc.). (6) Transfer your songs again to the player I hope this helps. Upgrading your firmware is always recommended as it will give you the latest enhancements available for the player.
Posted on Apr 25, 2007
Song screwups Sansa c250
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Nov 11, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Downloaded music and when i disconnect from computer it's not on the Sansa
you need to get the full-blown subscription to get those songs to play
Jul 31, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e270
The song does not have transfer rights - you must upgrade to Napster To Go.
Jun 21, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e250 computer problems
Try using Windows Media Player instead, and see if you get the same result. If it loads in Windows Media Player, then the problem is with WinAmp and not your Mp3 player. When you say it loads half-way, do you mean it loads half the songs and then shuts off? Is the Sansa running on low battery? WinAmp has some kind of update released in the past week - did you download the update, and then experience the problem? It's probably not this, because other users have had the same problem that you are reporting since at least Christmas 2007.
The following is an advice from another Sansa user, so I haven't been able to verify it myself:
"I have to have WinAmp open and a song playing then connect my player and then it will work fine. If I just connect my player then start WinAmp it crashes"
If all of the above fails, reformat your player and start over from scratch. Let me know how everything works out - this is an issue that not even the Sansa website seems to have an answer for.
-Tha Mp3 Doctor
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Reads Bad Track
If you changed the name of the song then thats the problem just simply change its name back to the original.
If thats not the problem then just delete the song or it will mess your sansa up and download it again for free with limewire
Mar 30, 2008 | SanDisk Sansa E280 MP3 Player
Only half of my music shows on a computer while the other half shows on another.
install winamp on your friends computer and see if they show up.
Are you saying the songs don't show up on the actual device on when you connect it to the computer?
Jan 08, 2008 | SanDisk Sansa c200 MP3 Player
HELP! plz!
It sounds like your Friend,Try to load something to your Player,Take the model 3 and make and Put it in the Browser and look for the Proper Software For it you might lose the music you have on it,But at least,It will Work
Jul 19, 2007 | RCA Lyra RD2217 MP3 Player
MUSIC JUST WONT PLAY ANYMORE
Renew Rhapsody subscription and resync
May 19, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
