Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
High CO emissions
My 95 Suburban won''t pass our county emissions for the 1st. time in 14 years for a higher than normal CO output.
Does anyone know what will cause this ?
The readings are as follow:
CO 2500RPM 2.15 The limit is 1.20 FAIL
CO Idle 3.22 The limit is 1.20 FAIL
This is a 454 throttle body type fuel injection
HC 2500RPM 37.8 Limit 220.0
CO2 2500RPM 13.53
HC Idle 121.2 Limit 220.0
CO2 Idle 12.86
EVAP Gas Cap 27.90 In H20 Limit 6.00
    Top Expert:
  • Chevrolet Master
  • 53,721 Answers
Run the fault codes and look for problem heated oxygen sensor ( HO2S) in the exhaust manifold , or problem oxygen sensor (O2S) after the cat converter, problem EGR system or problem cat converter
Posted on Apr 05, 2017
95 chevy astro van won't pass high emissions nox at low speed
If its higher mileage check the EGR valve. Famous for being clogged on those engines. Assuming it has emission friendly exhaust.
Nov 04, 2013 | Chevrolet Silverado 1500 Cars & Trucks
My 85 nissan pick up wont pass smog cause pollution number is to high. could it be vacuum hose leak?
Where do you live? Some locations (states/provinces, counties/parishes, and cities provide a waiver for vehicles older than 25 years. Check out your area's regulations. You may be able to avoid the emissions test completely. Good luck.
Oct 10, 2013 | Nissan Pickup Cars & Trucks
Hello...I have a '95 GMC K2500 Suburban with a 5.7L that failed a recent emissions test. I replaced the spark plugs, removed and cleaned the EGR...cap, rotor wires look OK...truck re-tested worst
Retarding the timing will cool the combustion which will lower the Hydrocarbon number,it will run bad but after a passed e test put the timing back to an advanced state which may help with the stumble.
Jul 22, 2017 | 1995 GMC Suburban
Not passing emissions
The NOx (Oxide of Nitrogen) level standard in the state of New Jersey is 1372. Anything higher than this number will fail emissions.
vas 5054a v19
Dec 19, 2012 | 2008 Chevrolet Suburban
95 f350, 460, high co levels
We're these at idle readings ? What were the off idle and cruise readings, if available ?
Jan 08, 2018 | Ford F-350 Cars & Trucks
I got a 95 corsica 2.2L failed emission test the carbon monoxide is too high the hydrocarbons passed but were higher than previous tests and the nox passed but were higher than previous tests...
sounds like a bad cat and o2 sensor. try a scanner, if the downstream sensor is attempting to make a 99% fuel trim adjustment, you can bet it needs changing along with the catalytic converter. get someone to follow you and accelerate hard, a rotton egg smell is a dead giveaway
May 28, 2010 | 1995 Chevrolet Corsica
87 gmc suburban wont pass idle test
check vacume pressure at carb. diaphram had sim. prob. with 78 caprice
Jan 06, 2009 | 1987 GMC Suburban
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
425 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
