Question about Mattel Barbie Girls MP3 Player
Barbiegirl won't connect
When i put the barbiegirl in the dock, the red light will blink a few times then it will turn off. i can access the usb drive to transfer songs but i don't know if it will charge...
when i go to the barbiegirl site, i cannot connect, message "try again later"
  • Anonymous Dec 29, 2008
    same problem
  • Anonymous Mar 22, 2009
    i plug it in the dock station and then it stays on the light but then it goes off.
Hi it will chrage have you ever thought that your chraging it to much and hey can u please tell me how to transfer songs ASAP
Posted on Dec 30, 2008
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Microphone PG58 won't turn on, it has a blinking red light when I push the power button
Your circuit board could be bad, but i would pull out the circuit board and spray contact cleaner onto the button, let it dry a few minutes and connect the battery and press that button quiet a few times and see if that fixes the problem.
Dec 06, 2012 | Shure PG58 Professional Microphone
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
Phone refuses to turn on. red light keeps blinking and can't connect to my pc
  1. Verify that BlackBerry Device Software is installed on the computer.
  2. If the BlackBerry smartphone is connected to a laptop computer using a docking station, disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
  4. If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
  5. In the BlackBerry Desktop Manager, double-click Application Loader.
  6. Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Oct 19, 2009 | RIM BlackBerry Pearl Smartphone
Drive won't boot
Thry this: turn your computer OFF. Gently unplug and replace the data cable connection to the computer several times. Do the same to the drive end of the cable. Leave one end unplugged. Turn on the computer and when the Mac os is set up and waiting for you, plug the drive in and see if the computer recognizes and reads the drive. The problem is usually corrosion on the contacts that prevent proper contact.
Jun 10, 2009 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Red qoutation light keeps blinking/a440 print dock
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Office Equipment & Supplies
Docking station
I had the same problem. I did need to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Mar 23, 2008 | Kodak EasyShare Z760 Digital Camera
IPOD SHUFFLE NOT RECOGNIZED
I had the same problem where my shuffle just turned off as if it ran out of battery power, and when i tried to plug it in the computer it wouldnt recognise it or i would get an unknow device error. I tried many of the 5r as much as i could but didnt work. Then finally yesterday i tried something new. I pluged the ipod into the computer and left it pluged in to the usb port and i noticed that every time i would lift the ipod from the dock (not all the way) that the light would blink green one time. So what i did was i positioned the ipod back on the dock then lifted it until the green light blinked and i turned it on, and it works now, the battery is charged. However i havent tried to plug it back in the computer to see what happens but i can listen to my music now.
Nov 07, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Mattel Barbie Girls MP3 Player Logo
236 people viewed this question
Top Mattel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mattel Audio Player and Recorder Expert? Answer questions, earn points and help others
