After changing motherboard operating system won't boot and get following message: SIS 190 PXE BOOTROM V03 use BEV/BBS no DHCP or proxy DHCP offered
SOURCE: pxe boot
The problem isn't that
these systems stay in active directory, its that the record of their
approval stays in WDS. My guess is that when WDS fails to find the
computer in AD it fails.
The solution was to remove the approvals from WDS using wdsutil.
WDSUTIL /Delete-AutoAddDevices /DeviceType:ApprovedDevices
I ran the above command and the PXE process worked.
I hope this helps someone else.
If you have to know about, view this link..
http://support.microsoft.com/default.aspx?scid=kb;en-us;259670
SOURCE: PXE booting errors
I don't have any experience with this product but I am 99.9% sure your problem is with Option 67. This path is from the root as defined for the TFTP server, i.e. root for the TFTP service is not the same as root for the server proper.
Most likely it should be something like:
\Boot\GhostNBF.vfd
