Question about HP Refurbished (07) HP PS R1500 XR ERM BATTERY REPLACEMENT (BULK OR PLEASE IM EMAIL OR CA HP (240789001) UPS System
Muliple email addresses
I HAVE THREE LAN NETWORKED COMPUTERS. I WANT TO COPY THE EMAIL ADDRESSES FROM ONE TO ANOTHER.
Called UPS
Posted on Dec 29, 2008
How to reset Barracuda 330 link balancer?
The Barracuda Link Balancer is assigned a default LAN IP address of 192.168.200.200. You can change this IP address in one of three ways:
  • In the web interface, go to the BASIC > IP Configuration page.
  • Connect a VGA monitor and a keyboard to the back of the Barracuda Link Balancer. Use the serial console. (username admin, password admin)
  • Press the RESET button on the front panel.
Pressing RESET for five seconds sets the LAN IP address to 192.168.200.200. Pressing RESET for eight seconds changes the LAN IP address to 192.168.1.200. Pressing the button for 12 seconds changes the LAN IP address to 10.1.1.200. You will notice the three LEDs on the front panel flash at the same time intervals.
Mar 10, 2014 | Barracuda Link Balancer 330 with 1-Year...
How to setup or enable wi fi from belkins to laptop wirelessly
  1. Connect the computer to one of the four LAN ports on your router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on "Use as Access Point" on the left-hand side of the opened page.
    Select Enable. This will give you the options to set the IP Address and Subnet mask for the router. These settings should match your existing network settings; by default the IP address will be set to 192.168.2.254 and the Subnet mask will be 255.255.255.0
Alternatively:
1. Click on LAN settings in the left hand menu.
2. When the LAN settings page opens you will make two changes.
Change the IP Address to something such as 192.168.2.47 or you can use 192.168.2.200. As long as the first three sets of numbers match your existing network, you will be fine.
3. Secondly you are going to disable or turn off the DHCP server.
4. Click the Apply Changes button.
Nov 11, 2010 | Belkin (F5D7633UK4A) Wireless Router
Got a hub genius GH4080SE and trying to connect computers, pls advise what is the steps?
Hardware Setup
1 Find the WAN or uplink port of the Ethernet hub. Typically, it is located on the rear of the unit, and it is often separate from the LAN ports.
2 Connect an Ethernet cable from the WAN port of the hub to either the Ethernet port of the internet modem or, if expanding a network, to an empty LAN port on the existing network’s router, switch or hub.
3 Plug an Ethernet cable into one of the LAN ports on the Ethernet hub and connect the other end of cable to the computer or device that will be added to the network. Repeat for any other devices that will need to be on the network.
4 Power up the Ethernet hub and the computers or other devices attached to it. On the front of the hub will be a series of LEDs that correspond to each LAN and WAN port on the hub. Every port that has a cable plugged into it should have one or more of the LEDs lit that represent that port. If not, check the connections and swap out the Ethernet cable if necessary.
Software Setup
1 Configure the network settings on each connected computer. If you are expanding a network and the network uses DCHP, or dynamic IP addressing, no configuration will be necessary. On networks using static IP addressing or on a new network setup using the Ethernet hub, each computer or device must be assigned a unique IP address. Local IP addresses must use the allowed “private” address pools that will not interfere with internet addresses. Acceptable addresses include 192.168.x.x, 172.16.x.x to 172.31.x.x, or 10.x.x.x. The “x” represents a number that is chosen by the user, from 0 to 254. All computers on the network should share the first three numbers in the address, with the final number representing the individual computer. In a network with three computers, for example, the first could be 192.168.1.1, the second could be 192.168.1.2 and the third could be 192.168.1.3, though the final number does not need to be sequential.
2 Click the “Start” button in Windows, select “Control Panel" and double-click the icon labeled “Network Connections.”
3 Right-click the icon for the Ethernet adapter and select “Properties.” Click on the check box marked “Internet Protocol (TCP/IP)” and press the “Properties” button.
4 Select the radio button labeled “Use the following IP address.” Enter a unique IP address for the computer and the applicable subnet mask. If a router is used on the network, enter the router’s IP address as the default gateway. Press the “OK” button and reboot if necessary.
5 Enable file and printer sharing from the “Properties” dialog for the Ethernet card if files will be transferred between the networked computers.
6 Click the “Start” button, select “Control Panel” and double-click on the “System” icon. Select the “Computer Name” tab and click on the button labeled “Change” to set the computer’s network name. In the “Computer Name” box, enter a unique name for the computer. In the “Member of” section, choose the radio button marked “Workgroup” and enter the workgroup of the network. If setting up a new network, this name can be change but all computers on the network must share the same workgroup name.
7 Verify that all computers can access the network and the Internet if connected.
Read more: How to Set up an Ethernet Hub | eHow.com http://www.ehow.com/how_4530475_set-up-ethernet-hub.html#ixzz0xnIzsGqa
see also Networking Diagram
Aug 27, 2010 | Genius GH 4080 SE 8-Port Ethernet Hub...
How do you scan digit prints from my 5300 scanner/printer to put on email????????????
Hi. There are lot of way on how to transfer your documents from old compter to nerw computer. First, you may use extarnal harddrive and copy all the documents from old PC to external HD and copy it to new PC. Second, If computers are in a network you may access the old computer from the network using the new computer and copy the files. Third, you may burn all the files from the old computer and then copy it from the new computer. Fourth, you may also do direct cable (LAN) connection to copy files from your old computer.
Aug 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
I need to know my brother mfc printer ip address
press menu go down to network or lan press ok or set.
choose wired lan for wired network or Wlan for wireless.
choose tcp/ip, choose ip address
Nov 15, 2009 | Brother 6-In-1 Printer/Fax/Copy/Scanner
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Aug 28, 2009 | Konica Minolta bizhub 200 Printer
Connection by network cable is not working.
When you connect two computers together without a network/LAN hub you need to use a cross over cable.
Both computers need to be in the same workgroup (name).
Both computers need to have different TCP/IP address and be in the same IP address range (ie a fixed IP address)
If you want to see and copy and move files between computers, the drives and or folders have to be sharing on.
This is the general network setup, you can restrict users on each computer with full access or limited access to drives and folders.
Mar 24, 2009 | HP Compaq Presario V5000Z Notebook
I am trying to connect a second laptop to my netgear router but I can only get limited or no connection?
Hi and welcome to FixYa,
Initially, let's try a quick fix:
  • determine and copy the details of the Networking of any of the other computers that can connect without a problem including the IP Address, Subnet Mask, Default Gateway and DNS servers;
  • open the Network properties of the LAN card or the WiFi card on the second laptop that has limited or no connection;
  • highlight Internet Protocol (TCP/IP);
  • click on the Properties button;
  • tick "Use the following IP Address"
  • enter the copied details (numbers) from the other computer;
  • the only difference would be that the new IP address should be slightly different;
  • example if the copied IP address is 192.168.0.11, pls make the new IP address 192.168.0.110;
  • all others stay the same.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
