Question about Haier Refrigerators
Need new part for Haier Refrigerator HTE14WAAWW. Where to buy???
HTE14WAAWW model number of my Haier Refrigerator. Need whole new bottom section of refrigerator except for the vegetable bins. plastic broke. Also, the door is not staying open. Any suggestions?I live in 19468 zip code and want to know where I can get new bottom piece.
  • 3,037 Answers
Hello agtcustomint
First of all, a door on a refrigerator not staying open is usually not much to be concerned about. One of the hinge brackets may be a little off of their original spot especially if you have kept a lot of heavy things in the door which may have bent one. Have a look.
Regarding the part, please see the following link
http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/HTE14WAAWW.aspx
let me know if you have any further questions about this
bestdarngood
Posted on Dec 28, 2008
    Genius:
  • 1,239 Answers
Hi
Misaligned and loose door hinges can cause the door to rock or sag slightly, making even a well-fitted gasket ineffective.
Step 1: If the door won't shut tightly, tip the refrigerator slightly backward by propping up the front of the unit or unscrewing the front leveling legs two complete turns. Experiment with this adjustment until the door stays closed, but don't tip the unit very far out of front-to-back level.
Step 2: If leveling doesn't work, tighten the hinge screws. You may have to open the door (especially the freezer door) to turn these screws. On some units, you may have to remove a hinge cap or trim to reach the screws; pry off the cap or trim with a screwdriver. Sagging and looseness can be corrected by shimming the door hinges. Loosen the hinge and place a hinge-shaped cardboard shim between the hinge and the door. Then tighten the hinge again. Sagging may also be caused by a wrongly placed shim. In this case, you can correct the problem by removing the shim. Experiment with the shims; you may be able to eliminate the sagging.
Step 3: If the door is warped, tighten the screws that hold the inner door shell to the outer door shell. You may have to change or adjust the door gasket after making this adjustment.
Step 4: Check the catch. Newer units have a magnetic catch on the door. If the door doesn't latch properly, remove the magnetic strike from the inner door shell and shim it slightly with a piece of thin cardboard. You may have to adjust the gasket to conform with the new shim.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try/star here. Or call 800-269-2609 for a more detailed response on availability, cost and delivery.
Good luck and Thank you for using FixYa.
The bottom part of the refrigerator is not cooling, freezer is ok
Are you sure about the model number being MTF2153GES? Usally when the fresh food section warms up it is an indication that there is a problem with the defrost system. If your model number is correct MTF2153GES then the refrigerator has a defrost timer behind the controls inside the fresh food section. I need to see if the defrost timer is stuck and causing the refrigerator to miss defrost. The defrost timer is=> 68233-3 Defrost Timer Let me know about the model number so I can continue to help solve this problem. . I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 11, 2014 | Maytag MTF2156GES Top Freezer Refrigerator
My refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
Jan 05, 2010 | Haier HTE21WAAWW Top Freezer Refrigerator
HTE14WAAWW - defrost water from freezer appears to be entering the lower cooling cabinet thru "ceiling" of lower cooling cabinet. Drain line plugged?
Yes, Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Dec 14, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
I have a Haier model HTE14WAAWW refrig. with top freezer. The refridge humes loudly. The freezer works, but to lower unit does not get very cold. The fan at the bottom, for the compressor does work. Please...
check the fan in freezer sounds like it is stuck [iced up ] or needs to b lubed at the back of freezer will see fan feel if fan is blowing or just humming
Sep 24, 2009 | Haier Refrigerators
My Haier compact frig runs all time, at #1 setting: freezes all
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Jul 05, 2017 | Haier HSB03 Compact Refrigerator
Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Apr 03, 2009 | Haier HSL06WNAWW Compact Refrigerator
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
I have a maytag refrigerator model 71184100 and there is water in the bottom of the refrigerator. It is a top freezer model with an ice maker. HELP! I cannot get the freezer floor out to check to see...
that is not a maytag model number. the model number will be in the refrig section (usually) and (usually in the uper left side) look up and to the left. find that and i will help no problem. but i am thinking you have a model that is about 12 to 18 years old that model is easy to do but you need to take the doors off first, then the center trim comes out, (it has screws some are used with door hinges) and the whole bottom slides out to you
May 15, 2008 | Maytag Refrigerators
Refrigerators Logo
71 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
