Question about Thumper Maxi Pro
Thumper stopped thumping
Have had this many years. it recently fell off the bed but still worked even though it sounded like there was something loose inside. now it will just hum and not vibrate. any ideas, any new jersey repair shops you know of. i miss it.
Rattling noise under car
The shield on the catylist converter
Dec 16, 2017 | Chevrolet Malibu Cars & Trucks
Loud thump under floorboard when auto transmission comming to a slow or stop
Could even be a loose exhaust system. Needs jacking up and a good inspection
Nov 26, 2017 | Cars & Trucks
Thumping sound when coasting in ford escape awd
I suspect there will be something loose in a CV joint, under load it will be held in place but when it is not under load it flaps around causing the thumping. You should be able to identify which side of the vehicle it is coming from then a mechanic should see it ASAP because if it lets go completely it will not only be dangerous and stop the vehicle from going anywhere it will be very expensive to fix the colateral damage.
Jun 03, 2012 | 2006 Ford Escape XLT
I hooked up a system in my truck had it for a year everything working fine.i listen to music really loud anyways i have my wires hiddin under my back seat well when someone layed the seat down it cut my...
Because even though your stereo is turned down the gain for the sub is set all the way up so it will still gain a small amount of signal. it is a flaw with some of the newer aftermarket stereos. try turning the nob until the thump stops then change the bass setting on your deck to compensate for the bass loss.
Jan 28, 2011 | Car Audio & Video
Something going on in either the drive belt or transmission belt area; The mower still drives but there is a hard knocking/thumping and you can feel it when you food is touching the brake pedal. Its a MTD...
It sounds to me like it may be a chunk missing out of your belt. Or warped pulley.
I dont think that it would be a broken spring because it would make the belt slip. Does it do it the same no matter how fast you are going?
But no matter what it is, if you start taking it apart. It should be easy to find. If its not the belts you can jack the rear wheels up take the belts off and work the pulleys and or wheels til you find it.
May 28, 2010 | Pool & Spa
Heater fell over while transporting in car,now it will not heat up even though the on lights come on to set power..
with heater unplugged, check all connections with an ohm meter, sounds like something got jarred loose. also check heating elements for resistance. if no ressistance, probably a broken heating element.
Jan 19, 2010 | Lakewood Oil-Filled Electric Radiator...
Microwave making dull thumping noise when NOT in use
I called a technician out today. Seems like the problem is the circuit board. It wasn't working properly and the sound is the fan. The fan is supposed to turn on when the microwave is in use and off when it is not. In this case, the fan continued even when the microwave was not in operation. A new circuit board has been ordered and will replace the old one when it arrives. For now, I can still use the microwave, but I have to unplug it everytime I finish heating something up. A little inconvenient, but at least it'll still heat my food up in the meantime.
Jun 24, 2009 | GE JVM2070 Microwave Oven
I have a 99 Mountaineer. Recently replaced the
If it is a continuous thump (ie thump, thump, thump) that changes in speed with the speed of the vehicle it is likely related to a tire problem.
If it happens when you hit a bump or immediately afterwards it is likely due to something loose or worn out in the suspension.
If it happens somewhat randomly and doesn't seem affected by bumps it may be a loose piece of trim, or something loose under the car getting knocked around by the winds.
Jun 13, 2009 | 2002 Mercury Mountaineer
Washer thumper
The thumping could also be a belt issue if it has a flat spot in it, especially if its a Frigidare Hybrid GE. To get to the element, sorry to say it, but will have to remove the drum and front of machine to get to it. Ohm out all the thermostats and thermofuses first. If it has the round element behind the drum (which it should) check the heater wire for breaks. If its a true GE it will have two wires, Frigidare Hybrid will only have one. Good Luck!!! Jim
Sep 03, 2007 | GE WSM2420T Top Load Stacked Washer /...
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Thumper Maxi Pro Logo
135 people viewed this question
Top Thumper Health & Beauty Experts
john h
Mai Lor
Are you a Thumper Health and Beauty Expert? Answer questions, earn points and help others
